Q: Is it possible to bind IPSEC to specific IP adress?
May 07, 2005 1 Replies
dbmasterguru
I will answer my question myself :-) Please give crypto map local-address a try. Cheers, DBM
Dear networkers,
We have a running VPN over Internet between our HQ and a remote branch which works fine. The HQ and remote branch use static IP addresses and the VPN is IPSEC with manual keying.
The VPN endpoints are a CISCO836 at the remote branch (connected to the Internet via ADSL/ISDN (3)) and a at the HQ: CISCO2820 (connected to the Internet via Ethernet (1)) which is also used as primary gateway to the Internet. See map below for details.
Recently we established a second/backup Internet link for availibility purposes using a CISCO2650 (connected to the Internet via E1 (2)). The setup and routing is fine, so we receive packets over (1) when the primary connection is up and running - and over (2) when the primary link (1) is down.
Now we experienced problems with the VPN connection when IPSEC packets are routed over the backup link instead over the primary link.
It looks like the CISCO836 is not able to establish the VPN link with CISCO2820 because packets are coming out from 1.2.3.1 (fa0/0@CISCO2820) instead of 1.2.4.1 (fa0/1@CISCO2820) which is the configured peer.
We already took a look at "IPSEC preferred peer"
DPD but this is not an option because we want to use manual keying.
Also configuring multiple peers in a crypto map is not possible with manual keying.
Here comes my question: is it possible to "bind" the IPSEC endpoint to a specific IP address (i.e. a loopback interface address on the CISCO2820) so that packets always flowing from/to this address only?
Cheers, DBM
PS: Here is the network topology map...
+- - - - + |HQ-Cloud| +- -+- - + HQ | ----------+----------+--------+---------- fa0/0 | 1.2.3.1/24 | fa0/0 +----+----+ +----+----+ |CISCO2820| |CISCO2650| | VPN SEC | | NON VPN | +----+----+ +----+----+ fa0/1 \ 1.2.4.1/24 / (1) \ / (2) \ / I N T E R N E T / / \ (3) \ 1.2.5.1/24 +----+---+ |CISCO836| +---+----+ | REMOTE BRANCH -------+------- | +- -+- -+ |Branch | | Cloud | +- - - -+
Please give
a try.
Cheers, DBM
