Problems with MTR (traceroute) through a PIX
Feb 19, 2006 1 Replies
So I've noticed the following interesting problem when trying to traceroute through a PIX 515E (7.0). I received the ICMP time exceeded packets back to my host, but the traceroute program I'm using (mtr) rejects them because the ID field in the returned ICMP header has been mangled!
Example:
12:56:51.175408 IP (tos 0x0, ttl 2, id 5653, offset 0, flags [none], length: 64) xxx.xxx.yyyy > 220.ge-0-1-0.cr2.lax1.speakeasy.net: icmp
44: echo request 0x0000: 4500 0040 1615 0000 0201 feaf 0a14 020f E..@............ 0x0010: 4511 52c5 0800 06e9 c616 2b00 0000 0000 E.R.......+..... 0x0020: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x0030: 0000 0000 0000 0000 0000 0000 0000 0000 ................
12:56:51.179808 IP (tos 0x0, ttl 254, id 0, offset 0, flags [none], length: 56) Loopback0.GW1.LAX1.ALTER.NET > xxx.xxx.yyyy: icmp 36: time exceeded in-trans 0x0000: 4500 0038 0000 0000 fe01 2517 8927 0264 E..8......%..'.d 0x0010: 0a14 020f 0b00 f4ff 0000 0000 4500 0040 ............E..@ 0x0020: 1615 0000 0101 f134 41d3 d8ca 4511 52c5 .......4A...E.R. 0x0030: 0800 ccda 0025 2b00 .....%+.
So the format of the ICMP time exceeded message should be: 0x00000000
Now if you look, the ICMP echo request has an ICMP header of: type: 0x08 (echo request) code: 0x00 checksum: 0x06e9 id: 0xc616 seq: 0x2b00
now the time-exceeded response should have the same exact thing in the last 64-bits of the packet, but it has: type: 0x08 code: 0x00 checksum: 0xccda id: 0x0025 seq: 0x2b00
So the id gets mangled somehow (which also screws up the checksum). mtr checks to see if the id of the response matches the echo request, so all these packets get dropped, and I get no traceroute results.
This only occurs when tracerouting through the PIX, traceroutes inside the PIX work fine.
Has anyone else seen this behavior?
Thanks.
-- James
