Problem with Live Communication Server through pix
Oct 13, 2005 0 Replies
I am trying to get LCS to run through a cisco 515 pix. I have clients trying to connect out the inside interface to the LCS server at a remote site. I thought I needed to add access lists but that did not help. Below is the sip debug. Searching the error came up empty. Any suggestions would be appreciated.
Cory
80: SIP::Found From addr "sip: snipped-for-privacy@aol.com" (26)
81: SIP::Found To addr "sip: snipped-for-privacy@aol.com" (26)
82: SIP::Found Call-ID 788f3529d6234fc89068d323b26a1cc7 (32)
83: SIP::Found CSeq 1
84: SIP: Found contact 10.0.33.71, port 12054 Found port 12054
85: SIP::Embedded IP 10.0.33.71/12054
86: NAT::NAT TCP 10.0.33.71/12054 from inside:10.0.33.71/4967 to wan:10.0.1.33/5060
87: NAT::reverse route: embedded host at inside:10.0.33.71/12054
88: NAT::find/create NAT rule for inside:10.0.33.71/12054 to wan:10.0.1.33
89: NAT::inside NAT with current xlate
90: NAT::embedded socket translates to wan:10.0.33.71/12054 Found port 12054
91: SIP::Embedded IP 10.0.33.71/12054
92: NAT::NAT TCP 10.0.33.71/12054 from inside:10.0.33.71/4967 to wan:10.0.1.33/5060
93: NAT::reverse route: embedded host at inside:10.0.33.71/12054
94: NAT::find/create NAT rule for inside:10.0.33.71/12054 to wan:10.0.1.33
95: NAT::inside NAT with current xlate
96: NAT::embedded socket translates to wan:10.0.33.71/12054
97: SIP::Embedded IP 0.0.0.0/0
98: NAT::ERROR: embed address is zero
99: Created SIP session for 10.0.33.71/4967 to 10.0.1.33/5060, 1 total From: sip: snipped-for-privacy@aol.com(26) To: sip: snipped-for-privacy@aol.com(26) Call-ID: 788f3529d6234fc89068d323b26a1cc7 (32)
100: NAT::requesting TCP conn for 10.0.33.71/12054 [0.0.0.0/0] from inside:10.0.33.71/4967 to wan:10.0.1.33/5060
101: NAT::reverse route: embedded host at inside:10.0.33.71/12054
102: NAT::pre-allocate connection for wan:10.0.1.33 to inside:10.0.33.71/12054
103: NAT::inside NAT with current xlate
104: NAT::outside NAT with current xlate
105: NAT::created TCP conn inside:10.0.33.71/12054 wan:10.0.1.33/0
106: SIP::Response 4xx received from wan:10.0.1.33/5060 to inside:10.0.33.71/496
7 Found port 12054
107: SIP::Embedded IP 10.0.33.71/12054
108: NAT::NAT TCP 10.0.33.71/12054 from wan:10.0.1.33/5060 to inside:10.0.33.71/4967
109: NAT::static route: embedded host at inside:10.0.33.71/12054
110: NAT::find/create NAT rule for inside:10.0.33.71/12054 to inside:10.0.33.71
111: NAT::receiver and embedded hosts on same interface
112: NAT::embedded socket translates to inside:10.0.33.71/12054
113: SIP::Found From addr "sip: snipped-for-privacy@aol.com" (26)
114: SIP::Found To addr "sip: snipped-for-privacy@aol.com" (26)
115: SIP::Found Call-ID 788f3529d6234fc89068d323b26a1cc7 (32)
116: SIP::Found CSeq 1
117: SIP::Deleting session for 10.0.33.71 to 10.0.1.33, 0 total From: sip: snipped-for-privacy@aol.com(26) To: sip: snipped-for-privacy@aol.com(26) Call-ID: 788f3529d6234fc89068d323b26a1cc7 (32)
118: SIP::REGISTER received from inside:10.0.33.71/4967 to wan:10.0.1.33/5060
119: SIP::Found From addr "sip: snipped-for-privacy@aol.com" (26)
120: SIP::Found To addr "sip: snipped-for-privacy@aol.com" (26)
121: SIP::Found Call-ID 788f3529d6234fc89068d323b26a1cc7 (32)
122: SIP::Found CSeq 2
123: SIP: Found contact 10.0.33.71, port 12054 Found port 12054
124: SIP::Embedded IP 10.0.33.71/12054
125: NAT::NAT TCP 10.0.33.71/12054 from inside:10.0.33.71/4967 to wan:10.0.1.33/5060
126: NAT::reverse route: embedded host at inside:10.0.33.71/12054
127: NAT::find/create NAT rule for inside:10.0.33.71/12054 to wan:10.0.1.33
128: NAT::inside NAT with current xlate
129: NAT::embedded socket translates to wan:10.0.33.71/12054 Found port 12054
130: SIP::Embedded IP 10.0.33.71/12054
131: NAT::NAT TCP 10.0.33.71/12054 from inside:10.0.33.71/4967 to wan:10.0.1.33/5060
132: NAT::reverse route: embedded host at inside:10.0.33.71/12054
133: NAT::find/create NAT rule for inside:10.0.33.71/12054 to wan:10.0.1.33
134: NAT::inside NAT with current xlate
135: NAT::embedded socket translates to wan:10.0.33.71/12054
136: SIP::Embedded IP 0.0.0.0/0
137: NAT::ERROR: embed address is zero
138: Created SIP session for 10.0.33.71/4967 to 10.0.1.33/5060, 1 total From: sip: snipped-for-privacy@aol.com(26) To: sip: snipped-for-privacy@aol.com(26) Call-ID: 788f3529d6234fc89068d323b26a1cc7 (32)
139: NAT::requesting TCP conn for 10.0.33.71/12054 [0.0.0.0/0] from inside:10.0.33.71/4967 to wan:10.0.1.33/5060
140: NAT::reverse route: embedded host at inside:10.0.33.71/12054
141: NAT::pre-allocate connection for wan:10.0.1.33 to inside:10.0.33.71/12054
142: NAT::inside NAT with current xlate
143: NAT::outside NAT with current xlate
144: NAT::found TCP conn inside:10.0.33.71/12054 wan:10.0.1.33/0
145: SIP::OTHER received from inside:10.0.33.71/4967 to wan:10.0.1.33/5060
146: mandatory requirements, dlen 0 mandatory 0, Content Length 0 Contact Addr
0.0.0.0/0
147: SIP::OTHER received from inside:10.0.33.71/4967 to wan:10.0.1.33/5060
148: mandatory requirements, dlen 0 mandatory 0, Content Length 0 Contact Addr
0.0.0.0/0
149: SIP::OTHER received from inside:10.0.33.71/4967 to wan:10.0.1.33/5060
150: mandatory requirements, dlen 0 mandatory 0, Content Length 0 Contact Addr
0.0.0.0/0
151: SIP::OTHER received from inside:10.0.33.71/4967 to wan:10.0.1.33/5060
152: mandatory requirements, dlen 0 mandatory 0, Content Length 0 Contact Addr
0.0.0.0/0
153: SIP::OTHER received from inside:10.0.33.71/4967 to wan:10.0.1.33/5060
154: mandatory requirements, dlen 0 mandatory 0, Content Length 0 Contact Addr
0.0.0.0/0
155: SIP::OTHER received from inside:10.0.33.71/4967 to wan:10.0.1.33/5060
156: mandatory requirements, dlen 0 mandatory 0, Content Length 0 Contact Addr
0.0.0.0/0
157: SIP::Timeout, deleting session
158: SIP::Deleting session for 10.0.33.71 to 10.0.1.33, 0 total From: sip: snipped-for-privacy@aol.com(26) To: sip: snipped-for-privacy@aol.com(26) Call-ID: 788f3529d6234fc89068d323b26a1cc7 (32)
