priority queueing over dialer interface
Apr 06, 2005 0 Replies
Hi
I have configured a dialer interface to use priority queueing, but no outgoing packets seems to get through the queues: the ip access lists used for the queues shows no hitcounts and the related PQ debug/show command shows no hitcounts as well.
Is it possible to use PQ on Dialer interface or there is restriction of some sorts? ( I have used it in the past on T1 serial interface and it was all ok, hitcounts and such ).
My dialer interface is ppp based and it layered on pppoe, then snap, then aal5, then atm, then dsl phy.
Thank you much to all
