PPTP on 837 with NAT
Feb 11, 2005 1 Replies
probably something like this:
! PPTP control protocol is carried in TCP using port 1723
ip nat inside static tcp 1723 interface 1723
! Let GRE traffic, PPTP control traffic and any other desired traffic thru
ip nat inside source list PPTP interface overload
ip access-list extended PPTP permit tcp permit gre any any ! Tighten this up once you get access working permit tcp any any eq 1723 ! Tighten up afterwards deny ip any any ! To be able to see acl match counter for denied traffic
interface ip nat inside ip access-group PPTP in
interface ip nat outside Ip access-group PPTP in
Hello all, I've got a 837 in which a port mapping for http works ok. But now I have to configure a PPTP VPN mapping to an internal server. The
837 performs NAT. Using the same kind of rule I used for the http, I can see that I can create a static map for IPSEC-Esp but not for the GRE protocol ? TIA
