Pix VPN Problem - ISAKMP: malformed payload
Jan 09, 2008 1 Replies
Can anyone help me with a PIX to Firebox vpn?
Here is my error:
ISAKMP: reserved not zero on payload 5! ISAKMP: malformed payload
OUTPUT:-
pixfirewall# ISAKMP (0): beginning Main Mode exchange crypto_isakmp_process_block:src:62.*.*.*, dest:82.*.*.* spt:500 dpt:
500 OAK_MM exchange ISAKMP (0): processing SA payload. message ID = 0
ISAKMP (0): Checking ISAKMP transform 1 against priority 20 policy ISAKMP: encryption DES-CBC ISAKMP: hash SHA ISAKMP: auth pre-share ISAKMP: life type in seconds ISAKMP: life duration (basic) of 8912 ISAKMP: default group 1 ISAKMP (0): atts are acceptable. Next payload is 0 ISAKMP (0): SA is doing pre-shared key authentication using id type ID_IPV4_ADDR return status is IKMP_NO_ERROR crypto_isakmp_process_block:src:62.*.*.*, dest:82.*.*.* spt:500 dpt:
500 OAK_MM exchange ISAKMP (0): processing KE payload. message ID = 0
ISAKMP (0): processing NONCE payload. message ID = 0
ISAKMP (0): ID payload next-payload : 8 type : 1 protocol : 17 port : 500 length : 8 ISAKMP (0): Total payload length: 12 return status is IKMP_NO_ERROR crypto_isakmp_process_block:src:62.*.*.*, dest:82.*.*.* spt:500 dpt:
500 OAK_MM exchange ISAKMP (0): processing ID payload. message ID = 0 ISAKMP (0): processing HASH payload. message ID = 0 ISAKMP (0): SA has been authenticated
ISAKMP (0): beginning Quick Mode exchange, M-ID of
-1641126510:9e2e6592 return status is IKMP_NO_ERROR ISAKMP (0): sending INITIAL_CONTACT notify ISAKMP (0): sending NOTIFY message 24578 protocol 1 VPN Peer: ISAKMP: Added new peer: ip:62.*.*.*/500 Total VPN Peers:1 VPN Peer: ISAKMP: Peer ip:62.*.*.*/500 Ref cnt incremented to:1 Total VPN Peers:1 crypto_isakmp_process_block:src:62.*.*.*, dest:82.*.*.* spt:500 dpt:
500 ISAKMP (0): processing NOTIFY payload 18 protocol 1 spi 0, message ID = 1449146501 return status is IKMP_NO_ERR_NO_TRANS crypto_isakmp_process_block:src:62.*.*.*, dest:82.*.*.* spt:500 dpt:
500 ISAKMP: reserved not zero on payload 5! ISAKMP: malformed payload
CONFIG
access-list 200 permit ip 192.168.1.0 255.255.255.0 10.1.0.0
255.255.0.0 access-list 200 permit ip 10.1.0.0 255.255.0.0 192.168.1.0
255.255.255.0
sysopt connection permit-ipsec crypto ipsec transform-set pixtransform esp-3des esp-md5-hmac crypto map testmap 10 ipsec-isakmp crypto map testmap 10 match address 200 crypto map testmap 10 set peer 62.*.*.* crypto map testmap 10 set transform-set pixtransform crypto map testmap interface outside crypto map partner-map 20 ipsec-isakmp crypto map partner-map 20 set security-association lifetime seconds
86400 kilobytes 536870912 ! Incomplete isakmp enable outside isakmp key ******************** address 62.*.*.* netmask
255.255.255.255 isakmp identity address isakmp policy 20 authentication pre-share isakmp policy 20 encryption des isakmp policy 20 hash sha isakmp policy 20 group 1 isakmp policy 20 lifetime 8912
Thanks !
Thanks, but its sorted now.
The firebox had a different lifetime for the key. 24 hours and 0kb. The pix wont allow 0kb. Pick a value (32000 was mine) and match them on both firewalls.
