PIX "Routing.."
Sep 14, 2005 2 Replies
PIX 6.3(3)
We now have multiple outside interfaces - different ISP's. The plan is to have one interface handle all web traffic (we will call that outside1)- the other VPN's (outside2).
To handle this - I figured I'd set the default route to use the ISP on outside1. All VPN routes would be have their routes defined to use outside2.
Inbound connections to the SSL VPN concentrator, however, are coming into outside2.
Will there be an issue with that because the default route points to outside1?? Or does the PIX know that since an inbound connection came on outside2 - use outside2 no matter what the def. route says???
Any other thoughts on this would be great also.
Thanks, Rick
In article , RS wrote: :PIX 6.3(3)
Sidenote: 6.3(3) had a security problem, fixed in 6.3(4).
6.3(5) is out now; it is a bug-fix release.
:We now have multiple outside interfaces - different ISP's. The plan is :to have one interface handle all web traffic (we will call that :outside1)- the other VPN's (outside2).
:To handle this - I figured I'd set the default route to use the ISP on :outside1. All VPN routes would be have their routes defined to use :outside2.
:Inbound connections to the SSL VPN concentrator, however, are coming :into outside2.
:Will there be an issue with that because the default route points to :outside1??
Yes.
:Or does the PIX know that since an inbound connection came :on outside2 - use outside2 no matter what the def. route says???
No, the PIX doesn't know that. The PIX always routes according to its routing table.
In PIX 6.3(3), the only policy routing that is supported has to do with OSPF.
What you might be able to do is "reverse NAT".
nat (outside2) 0.0.0.0 0.0.0.0 0 0 global (inside) SOMEIP route outside2 host SOMEIP WANROUTERIP
If you do this (and make sure to exempt the VPN traffic), then any outside source IP that comes in to outside2 will be PAT'd to SOMEIP. When the SSL concentrator replies to those packets, the 'route' ensures that the reply will go back out the outside2 interface. If SOMEIP is in the same subnet as the outside2 interface then you can skip the 'route' statement.
I do not know whether this NAT step will interfere with SSL... I don't -think- it will.
Thanks for the reply. I had made an incorrect assumption - which just kills me. The idea that the route command included a metric - not the case - grrrr... You get a single route - that's it. So anything "fancy" (though not really fancy eh?) would need to be accomplished with a router or other appliance (see Radware's Linkproof)...
PIX 7.0 doesn't address this either. And I'm not totally sure about running IOS FW - say on an ISR platform (28xx,38xx)... If that is the way to go, then why would Cisco continue to develop the PIX? Something tells me there is a reason to stay PIX - but what??
Anyway, thanks again.
