Cisco 1841 VPN and public IP addresses
Nov 21, 2006 0 Replies
Hello,
We have a cisco 1841 network equipment and we use it IPSEC VPN with several clients (tunnel mode). Everything works well with only one public address (we have tested it with 2 ipsec tunnels).
However, for personal reasons (in particular accounting and global QoS) we had to set up every tunnel with a different public IP on each. So we have problem during IKE phase because every tunnel try to set up with the main public IP off the router.
Is there any solution to configure the router to use a specified public IP address with a tunnel ?
Is the solution vrf ?
Thanks in advance,
Best regards, Julde
