Pix 515 E - ASDM errors
Oct 26, 2005 1 Replies
Hi, when I add or delete a rule at 1 specific interface in ASDM and apply changes my Pix' cpu raises up to 100% immediately and no communication is possible through it - I lose all connectivity. After about 1 minute the cpu cools down to somewhere between 20 and 50 % and communications can start again. When I do changes on another interface - everything ok. If I do the same changes on the problematic interface on the cli everything is fine. I use currently Pix 7.0.2.4 and ASDM 5.0.1. I already used 7.0.1,
7.0.2.1 and 7.0.2.2. Nothing better. Anybody seen this or have an explanation for it? Thx
That sounds as if the PIX is busy "compiling" the ACLs.
But if so then the CLI would, I think, compile the ACLs as well.
