Pix 501 Port Redirection Nightmares
Oct 23, 2007 1 Replies
Hi, I'm having some difficulty setting up port redirection on my PIX
501. I'd like to use my torrent program which operates on port 56317. I've searched forums for days looking for an answer that works for me, with no avail.
I'm new to Cisco, which is the basis of my problem. Please help me. How do I firstly, remove these access-lists I've entered into the firewall trying to configure it. Secondly, how do I configure the PIX
501 correctly?
Thank you very much for your time. Included is the presently messed-up configuration. Thank you.
: Saved : Written by enable_15 at 10:23:32.147 UTC Tue Oct 23 2007 PIX Version 6.3(5) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password .52vte67Gbpz.kce encrypted passwd .52vte67Gbpz.kce encrypted hostname prism domain-name ciscopix.com fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names object-group service torrent tcp port-object eq 56317 access-list outside_access_in permit tcp any interface outside eq
56317 access-list outside_access_in permit tcp any any eq 56317 access-list allow_inbound permit tcp any interface outside eq 56317 access-list inside_outbound_nat0_acl permit ip any 192.168.1.192
255.255.255.192
access-list 109 permit tcp any interface outside eq 3724 access-list 109 permit udp any interface outside eq 3724 pager lines 24 mtu outside 1500 mtu inside 1500 ip address outside dhcp setroute ip address inside 192.168.1.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm ip local pool vpns 192.168.1.220-192.168.1.230 pdm location 0.0.0.0 255.255.255.255 inside pdm location 0.0.0.0 255.255.255.0 inside pdm location 192.168.1.108 255.255.255.255 inside pdm location 192.168.1.192 255.255.255.192 outside pdm location 10.1.10.0 255.255.255.0 outside pdm location 192.168.1.1 255.255.255.255 outside pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list inside_outbound_nat0_acl nat (inside) 1 0.0.0.0 0.0.0.0 0 0 timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local http server enable http 192.168.1.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection permit-pptp telnet 192.168.1.0 255.255.255.0 inside telnet timeout 5 ssh timeout 5 console timeout 0 vpdn group PPTP-VPDN-GROUP accept dialin pptp vpdn group PPTP-VPDN-GROUP ppp authentication pap vpdn group PPTP-VPDN-GROUP client configuration address local vpns vpdn group PPTP-VPDN-GROUP pptp echo 60 vpdn group PPTP-VPDN-GROUP client authentication local vpdn username delician password ******** vpdn enable outside vpdn enable inside dhcpd address 192.168.1.2-192.168.1.33 inside dhcpd lease 3600 dhcpd ping_timeout 750 dhcpd auto_config outside dhcpd enable inside terminal width 80 Cryptochecksum:c6f1fab122c8d8ef719ab32a3caa7ed4 prism(config)#
snip..
Hmmm, long time since I had to do this, from memory the commands I think you want to port forward are:
static (inside,outside) tcp interface 56317 Internal_IP_Address 56317 netmask 255.255.255.255
access-list outside_access_in permit tcp any any/Your_Public_IP eq 56317
access-group outside_access_in in interface outside
Are you sure that this is TCP and not UDP. I did use a Torrent program a while back and something told me it used UDP. There again could be wrong.
Good luck
Regards
Darren
