PBR + BGP?
Jan 30, 2006 0 Replies
PBR + BGP? open original image
Is there any reason this wouldn't work? I came across this sample cfg using ospf but the it seems to me that the same principles would apply in a multihomed bgp scenario. if the preferred hop as defined with pbr goes away, the path to it shouldn't be broadcast via another provider, and therefore the routing table based path would take over. Am I correct?
thanks
