OSPF problem
May 30, 2006 2 Replies
Hello, I have this topology
Internet/ISP | | | Linksys Router (WRT54G) (Nat-ted) | 192.168.1.1 |(Ethernet - Point-to-Point OSPF) | 192.168.1.100 Router1 |10.10.10.1/30 | (Point-to-Point Frame Relay; Point-to-Point OSPF) |10.10.10.2/30 Router2
Router1 Conf.
------------ int e0 ip ospf net point-to-point ip addr
int s0.1 p ip ospf net point-to-point ip addr frame-relay interface dlci xxx
router ospf 1 net 192.168.1.0 0.0.0.255 a 0 net 10.10.10.0 0.0.0.3 a 1
From Router1 I can ping Linksys Router and Internet and using the name-server as well.
Router2 Conf
------------ int s0.1 p int s0.1 p ip ospf net point-to-point ip addr frame-relay interface-dlci xxx
router ospf 1 net 10.10.10.2 0.0.0.3 a 1
From Router2, I can ping Router 1 eth and serial but not Linksys Router
192.168.1.1.
and Yes, I've tried with ospf broadcast as well on eth but no luck.
on the linksys put in a static route for
10.10.10.0 255.255.255.252 towards the ip for router 1 eth0...
I assume the linksys is not running ospf with the 2 routers ? if so its not aware of the 10 net interarea route...
On router 2, verify you can see
show ip route 192.168.1.1 it should be towards router 1, who will know to use its static route to linksys 192.168.1.1
this has nothing to do with area type.
Login to Router 1 and use sh ip ospf neighbor command and see if the router is talking with the Linksys router. I suspect that it does not know about the 10.0.0.0 network.
Joel VanFleet
David Sudjiman wrote:
