Need help with nonat
Nov 14, 2005 1 Replies
I have a network that will be doing PAT on the pix to get to the internet. The internal addresses are controlled by our network, so I want to route the internal block away from PAT when they are accessing our VOIP system and not the internet. VOIP will not work through NAT in this scenario...so I need it to bypass NAT altogether and just access
172.16.100.1/24 directly.
right now
ip address 64.x.x.x 255.255.255.252 ip address inside 172.16.1.1 255.255.255.0 global (outside) 1 interface nat (inside) 1 0.0.0.0 0.0.0.0 0 0 route outside 0.0.0.0 0.0.0.0 64.x.x.x 1
This allows all traffic internall to be PATd to 64.x.x.x and go out to the internet. Let's say the VoIP server is on the 172.16.100.1/24 network.
How can I get all traffic from 172.16.1.1.24 to go direct to
172.16.100.1/24 without being NATd. Just direct access?
Any help would be greatly appreciated.
In article , wrote: [PIX]
;VOIP will not work through NAT in ;this scenario...so I need it to bypass NAT altogether and just access ;172.16.100.1/24 directly.
access-list voip_nonat_acl permit ip 172.16.1.0 255.255.255.0 172.16.100.0
255.255.255.0 nat (inside) 0 access-list voip_nonat_acl
