NAT Solution
Apr 10, 2009 4 Replies
Jump to replies (4)
We're needing to implement a solution whereby we can reroute traffic based on source address to a different resource. Basically, the default behavior would let the packet route to the normal destination, but anyone configured in a list would be shunted off to an alternate resource.
We could do this via layer 3 or layer 4 translation of some sort, or even a set-next-hop sort of arrangement. I'm trying to stay away from source-based routing, because we're talking about approximately
400Mbps worth of traffic here, so I want it to be as resource-friendly as possible. We've got some fairly beefy hardware at our disposal (Cat6500 w/SUP720,PFC3,MSFC3) so I'm wondering what can be leveraged.
The list of sources will likely be around 50,000-100,000 entries long and updated by an external source. I looked at the Cisco ACE module, but it can't do it via traditional NAT processes due to the logic flow and it's route-map features would be limited to 16,000 entries.
At this point, I'd be willing to use something Cisco or non-Cisco to accomplish this task. Are there any recommendations?
I think you need to come up with a new solution because I don't know of any device that would be able to do this. What is it that you are trying to accomplish? This is so wrong on so many levels... How would you even manage a list of 50 to 100 thousand source addresses?
The updates will be automatically generated, based on metrics determined by a daemon. With the Cisco ACE module, you can feed it configuration updates via XML. There's got to be a way...
But what is you are trying to do? Why do you need to route traffic based on source address? There is more than one way to do anything and the method you have suggested is not workable. If you provide more information someone can come up with a better solution. For example, why not send the traffic directly to the correct destination using GSLB or if this is an HTTP application you can write a CGI to issue a redirect to the correct destination.
define an access list capturing the source address's then do a route map setting next hop to the new route ?
