mirror port 2621xm
Jun 08, 2009 4 Replies
Jump to replies (4)
Howdy,
I am trying to setup port mirroring on a Cisco 2621xm. i issue the standard command "monitor session 1 source interface fastethernet 0/1 both" - and the error i receive is: "% Invalid input detected at '^' marker." (the ^ pointer is at 'f' of fastethernet). Yes i have 2 fastethernet interfaces (please see below output). i have found no documentation stating that i am unable to setup port monitoring / port spanning on a cisco 2621.
Thanks in advance quinn
gateway(config)#monitor session 1 source interface fastEthernet 0/1 both ^ % Invalid input detected at '^' marker.
---------------------------------------------------------------------------------------------------------------------------------------------- FastEthernet0/1 is up, line protocol is up Hardware is AmdFE, address is 0009.e850.7401 (bia 0009.e850.7401) Internet address is 192.168.1.4/24 MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 100Mb/s, 100BaseTX/FX
FastEthernet0/0 is up, line protocol is up Hardware is AmdFE, address is 0009.e850.7400 (bia 0009.e850.7400) Internet address is 192.168.0.1/29 MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 100Mb/s, 100BaseTX/FX
Cisco IOS Software, C2600 Software (C2600-ADVSECURITYK9-M), Version
12.4(15)T8, RELEASE SOFTWARE (fc3) Technical Support:
(c) 1986-2008 by Cisco Systems, Inc. Compiled Mon 01-Dec-08 14:23 by prod_rel_team
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
gateway uptime is 4 days, 2 hours, 53 minutes System returned to ROM by reload at 17:08:38 AEST Thu Jun 4 2009 System restarted at 17:12:09 AEST Thu Jun 4 2009 System image file is "flash:c2600-advsecurityk9-mz.124-15.T8.bin"
Nope, you can't. Only on switch ports. FastEthernet 0/1 is a layer-3 router port, so no port mirroring.
thanks Doug.
Any other way to capture > snipped-for-privacy@gmail.com writes:
The two traditional ways are if the traffic isn't too heavy, and you don't need the actual packets, to setup port ACL filters to watch for the traffic you want to detect and log it. Or Netflow.
Or, put in a sniffer upstream of it with a switch that can port mirror, or a hub.
You can of course debug ip packet [det]. Horrendous performance hit to the extent of losing management connectivity in some circumstances. Router might need power off to recover.
Worth noting that the latest, greatest 12.4T has integrated packet capture, can export to pcap file. Not tried it yet:-( Sounds a bit like pix and more.
Don't suppose it would run on 2621xm, but might be worth checking.
