Match protocol http - problems in regex
Jul 31, 2010 4 Replies
Jump to replies (4)
Hello
I have troubles in this:
router(config-cmap)#match protocol http url
*(torrent|thepiratebay|isohunt|entertane|demonoid|btjunkie|mininova|flixflux)* Assertion(text[n+1] == ')') failed at line 606 func parse_atom() file ../inspect/re_regexp.c Assertion(text[n+1] == ')') failed at line 606 func parse_atom() file ../inspect/re_regexp.c Assertion(text[n+1] == ')') failed at line 606 func parse_atom() file ../inspect/re_regexp.c Assertion(text[n+1] == ')') failed at line 606 func parse_atom() file ../inspect/re_regexp.c
and it doesnt work.
I would like to create a class map that drops all http:// *word* (where word is one of this word list). Since I tried to put them one by one but it tells me that the max limit is
24 entries.. I would like to put them in a few of large lines.
(torrentorrent|thepiratebay|isohunt|entertane|demonoid|btjunkie|mininova|flixflu\x) (vertor|h33t|zoozle|bitnova|bitsoup|meganova|fulldls|btbot|fenopy|gpirate) (sumotorrent|bitmonster|azureus|utorrent|vuze|torrentreactor|commonbits) (torrentz|bitlord|warez|bit-torrent)
I am not able to insert them in the match protocol http url I can put them one by one but after the first 24 it stops accepting them. I am working actually (for test) on a C877 48F/256D with 15.0(1)M2 advipservices k9 ios. can you help me ?
I would like to implement them on a C2651xm 48F/256D that will work as single appliance.
thank you
This is not a feasible way of blocking sites you don't want. There are just too many of them, and their names change too frequently.
I know that it is better a proxy server, but since Cisco has some L7 filtering I would like to use it!
"Rob" ha scritto nel messaggio news: snipped-for-privacy@xs8.xsall.nl...
Meanwhile, at the comp.dcom.sys.cisco Job Justification Hearings, Elia S. chose the tried and tested strategy of:
If you just want to use router features for the hell of it, and you know using a proxy is a better idea, then how about using WCCP?
"alexd" ha scritto nel messaggio news: snipped-for-privacy@ale.cx...
Yesterday in the evening, I thank seriously about a squid proxy with wccp :)
