Loadsharing
Jan 18, 2006 5 Replies
Jump to replies (5)
Hi all,
We got a discharged Office connected through 2 Leased-Lines with 2Mbit each.
-----------Modem------2Mbit-----Modem------------ Switch channel channel Switch -----------Modem------2Mbit-----Modem------------
The switches are connected with ethernet to the modem. The switches are connected with a trunk end the two connections are configured as a channel.
Now, is it possible to share and not balance the bandwidth? (Load-balancing with the port-channel)
thanks in advance
regards Pat
r u saying that u dont want to use etherchannel? There are many options to load balance etherchannel trafic, but keep in mind it is never balanced 50-50.
I'm looking for a solution, that ONE individual User can use more than
2Mbit temporary. So load-balancing with MAC-, IP-Address or Port is not desired.
If u had a router at both ends, u could creat two tunnels and load balance across them..Sorry, I dont know much more than that..
Multilink PPP? Need routers and not switches though.
Routing and per packet load balancing?
And many other similar products.
