Is HSRP and VRRP compitable.
Jun 26, 2006 4 Replies
Francois Labreque
No. They are not compatible. Recent versions(12.2(13)T and above) of IOS support VRRP. For the same reason the English and Japanese are not compatible. They are means of achieving the same result that were invented by different people.
Hello All,
Is HSRP and VRRP interoperable. we have a Cisco router (Cisco Catalyst 6000 Series Switches Module Switch Feature Card (MSFC)) and a Juniper router (Juniper M20 series). We have HSRP on Cisco and VRRP on juniper and is it possible that they can interoperate. Can this setup protect the same Virtual IP. If not why? if yes why?
Thanks in advance.
hi sumanth
No HSRP is Cisco Propretary protocol, so u cannot use with other products. So u need to configure VRRP in both cisco and juniper .
rgds suman
Do you have any expirience with the compatibility of VRRP of Cisco and the Linux VRRPd?
Cheers
Marco
