int range command
Feb 07, 2005 1 Replies
did you try
int range ATM1/ima0.1 - ATM1/ima0.95
I was unsuccessful in trying to use this command and I think I'll need to occasionally for work with an isp
They have a range of ints as follows.
interface ATM1/ima0.1 point-to-point ...... interface ATM1/ima0.95 point-to-point
I tried the following syntax w/o success
int range ATM1/ima0.1 - ima0.95
int range ATM1/ima0.1 - 0.95
int range ATM1/ima0.1 - .95
