How to go about single Cisco IP phone on SOHO network
Aug 24, 2005 3 Replies
www.BradReese.Com
Hi Chris, You may wish to investigate the Vonage SoftPhone: please keep in mind that Vonage "customer support" has gone totally down the tubes. Sincerely, Brad Reese Cisco Repair Service Experts Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA/Canada Toll…
Hello all - new to VOIP so bear with ;-)
Problem - costs involved communicating back home when away
Solution - VOIP
Here's the big question, current hardware is:
Toshiba laptop with Toshiba IP phone software Cisco SOHO 97 ADSL router (fixed WAN IP address)
Can I connect a Cisco IP phone to the router back home and place VOIP calls from the laptop (via cybercafe etc).
Do I need any other hardware?
Do I need a VOIP service provider, or can I call straight into the fixed IP address?
Thanks in advance!
Chris
Hi Chris,
However, please keep in mind that Vonage "customer support" has gone totally down the tubes.
Sincerely,
Brad Reese BradReese.Com Cisco Repair Service Experts
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA/Canada Toll Free: 877-549-2680 International: 828-277-7272 United Kingdom: 44-20-70784294
Make it easy.
Get VMWare and a copy of CallManager.
Install both.
Put IP communicator on your laptop.
Point it to a public IP for your CM.
Put a 7960 on your LAN
Call home like a crazy person.
(you will need to punch a couple of holes through your firewall TCP 1720,
2000, and UDP 16535 to 32768)
Jonathan
Why would anyone want to use vonage? (yeah yeah I know there are people who just want a working phone) You have to pay extra for their softphone anyway. Not to mention the total lack of flexibility with them.
