how to delete vty interface
Sep 08, 2005 1 Replies
Doan
Try "no line vty 5 15". You can enable both telnet and ssh with "transport input telnet ssh". Use the "login local" command if you want to use the local username database. Doan
Hello I create a second vty accidently, when enabling ssh on my remote router. Does anyone know how to delete this interface?. Is it possible to enable both telnet and ssh on the router? I also removed the password because i enable login to the router with username and password. thanks.
this is my config line vty 0 4 password 7 transport input ssh line vty 5 15 transport input ssh
Doan
