help with ipsect tunnel between 1700 routers
Sep 06, 2005 2 Replies
Hello I set up my ipsec tunel for some reason only the tunnel with our pix stays alive. all the other tunnels betweek 17xx routers come and go on this router. Can anyone explain what is going on? thanks
00:50:18: ISAKMP (0:5): processing SA payload. message ID = 997939343
00:50:18: ISAKMP (0:5): Checking IPSec proposal 1
00:50:18: ISAKMP: transform 1, ESP_3DES
00:50:18: ISAKMP: attributes in transform:
00:50:18: ISAKMP: encaps is 1
00:50:18: ISAKMP: SA life type in seconds
00:50:18: ISAKMP: SA life duration (basic) of 3600
00:50:18: ISAKMP: SA life type in kilobytes
00:50:18: ISAKMP: SA life duration (VPI) of 0x0 0x46 0x50 0x0
00:50:18: ISAKMP: authenticator is HMAC-MD5
00:50:18: ISAKMP (0:5): atts are acceptable.
00:50:18: ISAKMP (0:5): IPSec policy invalidated proposal
00:50:18: ISAKMP (0:5): phase 2 SA not acceptable!
00:50:18: ISAKMP (0:5): sending packet to x.x.x.x(R) QM_IDLE
00:50:18: ISAKMP (0:5): purging node 775745655
00:50:18: ISAKMP (0:5): Unknown Input for node 997939343: state = IKE_QM_READY, major = 0x00000001, minor = 0x0000000C
00:50:18: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at x.x.x.x
In article , wrote: :Hello I set up my ipsec tunel for some reason only the tunnel with our :pix stays alive. all the other tunnels betweek 17xx routers come and go :on this router. Can anyone explain what is going on?
What happened when you tried my earlier suggestion of switching from MD5 to SHA ?
I think my tunnel with the pix is the only one working, when i debug ipsec i get
00:41:03: IPSEC(encapsulate): error in encapsulation fs_encap_decap_fail 00:41:08: IPSEC(adjust_mtu): adjusting path mtu from 1500 to 1470, (identity) local= x.x.x.x, remote= x.x.x.x, local_proxy= 10.x.x.0/255.255.255.0/0/0 (type=4), remote_proxy= 10.x.x.0/255.255.255.0/0/0 (type=4)
