Trying to Connect NCP CE Client to PIX using Preshared Keys...
Jun 23, 2005 0 Replies
I have my PIX set up for both Certs and PreShared Keys.
I've been able to get the Cisco VPN Client to connect via Certs with no issues.
I've been able to get other Routers to Connect using PreShared Keys using the name of the router as the VPDNGroup name with no issues.
On the NCP Client In the Profile settings under Identities, I've tried several ID Types. I'm not sure which one I'm supposed to use. I thought it was ASN1 Group name, though I've tried them all.
On the PIX I've seen the Following which makes me believe the ID Type is not set right.
VPN Peer:ISAKMP: Peer Info for 166.220.45.45/500 not found - peers:10
Where that IP address is the IP Address of the Client. Though since my device changed IP every time I connect to the internet I cannot do an Identity via IP. I'd like to use a name/group name/string. This works for my other PreShared Key Clients as they also have a DHCP WAN address.
(Link to Clinet Software:
Please Advise.
Thanks!
ScottSupport for NAT-T version - 3 XMIT_MSG3_MAIN - sx66 IPSDIAL->FINAL_TUNNEL_ENDPOINT:204 .145.245.017 RECV_MSG4_MAIN - sx66 Turning on NATD mode - sx66 - 1 XMIT_MSG5_MAIN - sx66 IPSDIAL - disconnecting from sx66 on channel 1. NCPIKE-phase2:name(sx66) - error - cleared by phase1 IPSDIAL - disconnected from sx66 on channel 1.
---------------------------------------- Cisco PIX
charlie# crypto_isakmp_process_block:src:166.220.9.6, dest:charlie_o spt:500 dpt:500 OAK_MM exchange ISAKMP (0): processing SA payload. message ID = 0
ISAKMP (0): Checking ISAKMP transform 1 against priority 8 policy ISAKMP: encryption AES-CBC ISAKMP: hash SHA ISAKMP: extended auth pre-share (init) ISAKMP: default group 2 ISAKMP: life type in seconds ISAKMP: life duration (VPI) of 0x0 0x0 0x70 0x80 ISAKMP: keylength of 128 ISAKMP (0): atts are not acceptable. Next payload is 3 ISAKMP (0): Checking ISAKMP transform 2 against priority 8 policy ISAKMP: encryption AES-CBC ISAKMP: hash MD5 ISAKMP: extended auth pre-share (init) ISAKMP: default group 2 ISAKMP: life type in seconds ISAKMP: life duration (VPI) of 0x0 0x0 0x70 0x80 ISAKMP: keylength of 128 ISAKMP (0): atts are not acceptable. Next payload is 3 ISAKMP (0): Checking ISAKMP transform 3 against priority 8 policy ISAKMP: encryption AES-CBC ISAKMP: hash SHA ISAKMP: auth pre-share ISAKMP: default group 2 ISAKMP: life type in seconds ISAKMP: life duration (VPI) of 0x0 0x0 0x70 0x80 ISAKMP: keylength of 128 ISAKMP (0): atts are not acceptable. Next payload is 3 ISAKMP (0): Checking ISAKMP transform 4 against priority 8 policy ISAKMP: encryption AES-CBC ISAKMP: hash MD5 ISAKMP: auth pre-share ISAKMP: default group 2 ISAKMP: life type in seconds ISAKMP: life duration (VPI) of 0x0 0x0 0x70 0x80 ISAKMP: keylength of 128 ISAKMP (0): atts are not acceptable. Next payload is 3 ISAKMP (0): Checking ISAKMP transform 5 against priority 8 policy ISAKMP: encryption 3DES-CBC ISAKMP: hash SHA ISAKMP: extended auth pre-share (init) ISAKMP: default group 2 ISAKMP: life type in seconds ISAKMP: life duration (VPI) of 0x0 0x0 0x70 0x80 ISAKMP (0): atts are not acceptable. Next payload is 3 ISAKMP (0): Checking ISAKMP transform 6 against priority 8 policy ISAKMP: encryption 3DES-CBC ISAKMP: hash MD5 ISAKMP: extended auth pre-share (init) ISAKMP: default group 2 ISAKMP: life type in seconds ISAKMP: life duration (VPI) of 0x0 0x0 0x70 0x80 ISAKMP (0): atts are not acceptable. Next payload is 3 ISAKMP (0): Checking ISAKMP transform 7 against priority 8 policy ISAKMP: encryption 3DES-CBC ISAKMP: hash SHA ISAKMP: auth... What? 64221? ISAKMP: default group 2 ISAKMP: life type in seconds ISAKMP: life duration (VPI) of 0x0 0x0 0x70 0x80 ISAKMP (0): atts are not acceptable. Next payload is 3 ISAKMP (0): Checking ISAKMP transform 8 against priority 8 policy ISAKMP: encryption 3DES-CBC ISAKMP: hash MD5 ISAKMP: auth... What? 64221? ISAKMP: default group 2 ISAKMP: life type in seconds ISAKMP: life duration (VPI) of 0x0 0x0 0x70 0x80 ISAKMP (0): atts are not acceptable. Next payload is 3 ISAKMP (0): Checking ISAKMP transform 9 against priority 8 policy ISAKMP: encryption 3DES-CBC ISAKMP: hash SHA ISAKMP: auth pre-share ISAKMP: default group 2 ISAKMP: life type in seconds ISAKMP: life duration (VPI) of 0x0 0x0 0x70 0x80 ISAKMP (0): atts are not acceptable. Next payload is 3 ISAKMP (0): Checking ISAKMP transform 10 against priority 8 policy ISAKMP: encryption 3DES-CBC ISAKMP: hash MD5 crypto_isakmp_process_block:src:166.220.9.6, dest:charlie_o spt:500 dpt:500 OAK_MM exchange ISAKMP (0): processing KE payload. message ID = 0
ISAKMP (0): processing NONCE payload. message ID = 0
ISAKMP (0:0): Detected NAT-D payload ISAKMP (0:0): NAT match MINE hash ISAKMP (0:0): Detected NAT-D payload ISAKMP (0:0): NAT does not match HIS hash hash received: ca fd 52 eb ca 2b 3e fa 47 23 49 83 a8 bd 7b 44 his nat hash : 17 5f 4e 86 7b b1 2d d0 2b a2 26 97 7e 8a 82 2e ISAKMP (0:0): constructed HIS NAT-D ISAKMP (0:0): constructed MINE NAT-D return status is IKMP_NO_ERROR crypto_isakmp_process_block:src:166.220.9.6, dest:charlie_o spt:4500 dpt:4500 ISAKMP: reserved not zero on payload 5! ISAKMP (0): deleting SA: src 166.220.9.6, dst charlie_o ISADB: reaper checking SA 0x15d1d1c, conn_id = 0 ISADB: reaper checking SA 0x15eb93c, conn_id = 0 ISADB: reaper checking SA 0x15d6bd4, conn_id = 0 DELETE IT!
VPN Peer:ISAKMP: Peer Info for 166.220.9.6/500 not found - peers:10
ISADB: reaper checking SA 0x15d1d1c, conn_id = 0 ISADB: reaper checking SA 0x15eb93c, conn_id = 0 ISADB: reaper checking SA 0x15e140c, conn_id = 0 ISADB: reaper checking SA 0x15dc59c, conn_id = 0 ISADB: reaper checking SA 0x15de6d4, conn_id = 0 ISADB: reaper checking SA 0x15d0174, conn_id = 0 ISADB: reaper checking SA 0x158020c, conn_id = 0 ISADB: reaper checking SA 0x147aa94, conn_id = 0 ISADB: reaper checking SA 0x15e03d4, conn_id = 0 ISADB: reaper checking SA 0x14b155c, conn_id = 0 ISADB: reaper checking SA 0xe4eb0c, conn_id = 0 crypto_isakmp_process_block:src:67.124.15.121, dest:charlie_o spt:500 dpt:500 ISAKMP (0): processing DELETE payload. message ID = 795482895, spi size = 16 ISAKMP (0): deleting SA: src 67.124.15.121, dst charlie_o return status is IKMP_NO_ERR_NO_TRANS ISADB: reaper checking SA 0x15d1d1c, conn_id = 0 ISADB: reaper checking SA 0x15eb93c, conn_id = 0 ISADB: reaper checking SA 0x15e140c, conn_id = 0 ISADB: reaper checking SA 0x15dc59c, conn_id = 0 ISADB: reaper checking SA 0x15de6d4, conn_id = 0 ISADB: reaper checking SA 0x15d0174, conn_id = 0 ISADB: reaper checking SA 0x158020c, conn_id = 0 DELETE IT!
VPN Peer: ISAKMP: Peer ip:67.124.15.121/500 Ref cnt decremented to:2 Total VPN Peers:10 ISADB: reaper checking SA 0x15d1d1c, conn_id = 0 ISADB: reaper checking SA 0x15eb93c, conn_id = 0 ISADB: reaper checking SA 0x15e140c, conn_id = 0 ISADB: reaper checking SA 0x15dc59c, conn_id = 0 ISADB: reaper checking SA 0x15de6d4, conn_id = 0 ISADB: reaper checking SA 0x15d0174, conn_id = 0 ISADB: reaper checking SA 0x147aa94, conn_id = 0 ISADB: reaper checking SA 0x15e03d4, conn_id = 0 ISADB: reaper checking SA 0x14b155c, conn_id = 0 ISADB: reaper checking SA 0xe4eb0c, conn_id = 0 crypto_isakmp_process_block:src:166.220.9.6, dest:charlie_o spt:4500 dpt:4500 ISAKMP: reserved not zero on payload 5! crypto_isakmp_process_block:src:166.220.9.6, dest:charlie_o spt:4500 dpt:4500 ISAKMP: reserved not zero on payload 5! crypto_isakmp_process_block:src:166.220.9.6, dest:charlie_o spt:4500 dpt:4500 ISAKMP: reserved not zero on payload 8! ISAKMP (0): deleting SA: src 166.220.9.6, dst charlie_o ISADB: reaper checking SA 0x15d1d1c, conn_id = 0 ISADB: reaper checking SA 0x15eb93c, conn_id = 0 DELETE IT!
ISADB: reaper checking SA 0x15d1d1c, conn_id = 0 ISADB: reaper checking SA 0x15e140c, conn_id = 0 ISADB: reaper checking SA 0x15dc59c, conn_id = 0 ISADB: reaper checking SA 0x15de6d4, conn_id = 0 ISADB: reaper checking SA 0x15d0174, conn_id = 0 ISADB: reaper checking SA 0x147aa94, conn_id = 0 ISADB: reaper checking SA 0x15e03d4, conn_id = 0 ISADB: reaper checking SA 0x14b155c, conn_id = 0 ISADB: reaper checking SA 0xe4eb0c, conn_id = 0
