Help with "Global" command
May 15, 2006 1 Replies
Hi
I'm doing the following in my new DMZ:
nat (dmz2) 0 x.x.x.64 255.255.255.240 0 0
My question is do I need a "global" statement with the above nat?
My Take on the above is that I don't need one, however there is another dmz configured on the pix and that has disabled nat aswell, but has a "global" command attached to it. So I'm rather confused.
Any help would be appreciated Thanks Dan
The answer is no.
Usually a nat statement always goes with a global statement , the global being the address(es) used for NATing.
The exception is when you do a "nat (interface) 0 ". A nat 0 means that you don't want to NAT; so if you don't NAT, you don't need to define a global address pool .
I never tried to enter a global (interface) 0 statement , but if the PIX accept it , it would be useless.
