Hello I think that the correct topic should be route-map
I need help about that:
This is the scenario:
Cisco 2650 with:
1 on-board FE (fast0/0) NM-4E - four eth ports from eth0/0 to eth0/4
This is the ideal interfaces assignements:
DMZ network 172.16.0.0/27 (gw 172.16.0.30) ----- fast0/0 172.16.0.9/27
C2650
Eth0/0 - Office LAN : 192.168.0.0/24 - 192.168.0.254 on this interface eth0/1 - NETWORK 01: 192.168.101.0/24 - .254 on this int eth0/2 - NETWORK 02: 192.168.102.0/24 - .254 on this int
On the router I have two dialer interfaces: dial1 and dial2
each one dialer interface connects to a remote vpn (they establish the connection via the fast0/0)
Once the dialers interface are both up, I need to let each interface go out using one specified dialer, example:
dialer1
