GRE question !
Dec 18, 2006 6 Replies
Jump to replies (6)
GRE question ! open original image
My two sites (site A & site B)are connecting via GRE tunnel, all ip traffic is allowed on the GRE tunnel. Both routers perform nat for any outbound packet toward internet.
When a workstation in site A connect to site B, will these packet go directly via GRE tunnel to site B ? WIll site A router perform NAT before the packet leaving router A ? I assume all outbound packet will perform NAT before leaving the router, is it correct ? If the answer is yes, how do I bypass NAT process when site A workstation connect to site B ?
take a look
Roman Nakhmanson
So if site A & site B routers formed a GRE tunnel interface, any traffic goes via the that tunnel interface will bypass NAT operation ?
Thanks, snipped-for-privacy@gmail.com =BCg=B9D=A1G
One more thing :
Both site routers are having NAT configured for local workstation connect to internet. My question is when there's a GRE tunnel interface configured, when site A workstation connects to site B, will NAT be performed ?
Ethernet 0 (LAN) ip address 200.200.200.0 255.255.255.0
Tunnel 0 xxx tunnel source aaa.aaa.aaa.aaa tunnel destination bbb.bbb.bbb.bbb (site B)
Loopback1 ip address 333.333.333.333
ip nat inside source list outbound interface Loopback1 overload
ip access-list outbound permit 200.200.200.0 0.0.0.255 any
yellow =BCg=B9D=A1G
Well, it will depend partly on what you have defined as an inside interface and an outside interface for NAT, as well as your 'ip nat inside ...' command. For NAT to happen, the packet must traverse an inside/outside pair of interfaces. Might help if you posted a full config... but I assume your tunnel does not have an 'ip nat outside' statement? If you 'show ip nat statistics' it will give you a bit more info about the nat config. And of course you could always 'suck it and see' while debugging NAT to see what happens. :o)
Regards,
Al
I'll try to post the full configuration file although it's big.
Yes the tunnel interface does not has 'ip nat outside command', only the outside interface has set. So in this case, any traffic thru the tunnel interface won't perform NAT, correct ? If I put 'ip nat outside' statement in tunnel interface, it will perform NAT operation ? Al =BCg=B9D=A1G
NAT happens when the intresting traffic matches some kind of creteria, on the interfaces you define with "ip nat outside" "ip nat inside".
Roman Nakhmanson
