freeswan 1.91 and ASA problem
Jun 07, 2008 2 Replies
Hi
I have problem with ipsec tunnel L2L between Freeswan and ASA. The tunnel disconnect yourself after 15-20 min. When I restart tunnel on Freeswan side tunnel connect again
In my syslog i get error like this:
Keep-alives configured on but peer does not support keep-alives (type = None)
QM FSM error construct_ipsec_delete(): No SPI to identify Phase 2 SA! Removing peer from correlator table failed, no match!
I configured key lifetime 86400s on the both side but when i make: sh crypto isakmp sa detail | include Life Auth : preshared Lifetime: 3600 Lifetime Remaining: 3228
I have only 3600s...why ???
ASA config:
crypto ipsec transform-set wwa_interia_pl esp-3des esp-sha-hmac crypto dynamic-map DYN_MAP_VPN_1 10 set transform-set tunel crypto dynamic-map DYN_MAP_VPN_1 10 set security-association lifetime seconds 288000 crypto dynamic-map DYN_MAP_VPN_1 10 set reverse-route crypto map outside_map 20 match address www_xxx crypto map outside_map 20 set peer 81.81.81.130 crypto map outside_map 20 set transform-set www_xxx crypto map outside_map 100 ipsec-isakmp dynamic DYN_MAP_VPN_1 crypto map outside_map interface outside crypto isakmp enable outside crypto isakmp policy 10 authentication pre-share encryption 3des hash sha group 2 lifetime 86400
tunnel-group 10.10.10.10 type ipsec-l2l tunnel-group 10.10.10.10 ipsec-attributes pre-shared-key *
access-list www_xxx; 1 elements access-list www_xxx line 1 extended permit icmp 10.11.0.0 255.255.0.0
10.200.200.0 255.255.255.0
freeswan 1.91 config:
config setup interfaces=%defaultroute plutodebug=none klipsdebug=none plutoload=%search plutostart=%search uniqueids=yes overridemtu=1364
type=tunnel authby=secret left=80.80.80.2 leftsubnet=10.11.0.0/16 leftnexthop= right=81.81.81.130 rightsubnet=10.200.200.0/24 rightnexthop=81.81.81.129 keyingtries=0 keylife=24h auto=add keyexchange=ike pfs=no auth=esp #ike=3des-sha-modp1024 esp=3des-sha1
on the ASA: sh crypto isakmp sa detail
IKE Peer: 81.81.81.130 Type : L2L Role : responder Rekey : no State : MM_ACTIVE Encrypt : 3des Hash : SHA Auth : preshared Lifetime: 3600 Lifetime Remaining: 3304
thanks for any help
Ted
I do not see anything referencing the SA time in the freeswan config, perhaps it is creating the tunnel, and freeswan is making the default SA time 3600?
IMHO i have the same time settings on ASA and linux
In ASA i have:
crypto ipsec transform-set www_xxx esp-3des esp-sha-hmac crypto dynamic-map DYN_MAP_VPN_1 10 set transform-set tunel crypto dynamic-map DYN_MAP_VPN_1 10 set security-association lifetime seconds 288000 crypto dynamic-map DYN_MAP_VPN_1 10 set reverse-route crypto map outside_map 20 match address www_xxx crypto map outside_map 20 set peer 10.10.10.10 crypto map outside_map 20 set security-association lifetime seconds 86400 crypto map outside_map 20 set transform-set www_xxx crypto map outside_map 100 ipsec-isakmp dynamic DYN_MAP_VPN_1 crypto map outside_map interface outside crypto isakmp enable outside crypto isakmp policy 10 authentication pre-share encryption 3des hash sha group 2 lifetime 28800
In freeswan:
keyingtries=0 ikelifetime=28800 keylife=24h keyexchange=ike spibase=0x200 pfs=no auth=esp
freeswan logs:
000 "www_xxx": 000 "wwa-cisco_vpn_asa": ike_life: 28800s; ipsec_life: 86400s; rekey_margin: 540s; rekey_fuzz: 100%; keyingtries: 0 policy: PSK+ENCRYPT+TUNNEL; interface: eth2; erouted newest ISAKMP SA: #8036; newest IPsec SA: #8037; eroute owner: #8037
Thank You for any help or clue Ted
