frame relay switch configuration issue
Apr 09, 2007 5 Replies
Jump to replies (5)
Hey. I'm working on configuring my network in a multipoint frame relay configuration.
Here is what i got.
FR - 2522 s3 - R3 s4 - R4 s5 - R5
R3 - 3640 s1/0 - FR
R4 - 3640 s1/0 - FR
R5 - 3640 s1/0 - FR
FR config
frame-relay switching ! interface Serial3 no ip address encapsulation frame-relay clockrate 64000 frame-relay intf-type dce frame-relay route 304 interface Serial4 403 frame-relay route 305 interface Serial5 503 ! interface Serial4 no ip address encapsulation frame-relay clockrate 64000 frame-relay intf-type dce frame-relay route 403 interface Serial3 304 frame-relay route 405 interface Serial5 504 ! interface Serial5 no ip address encapsulation frame-relay clockrate 64000 frame-relay intf-type dce frame-relay route 503 interface Serial3 305 frame-relay route 504 interface Serial4 405
R3 interface Serial1/0 ip address 10.12.16.3 255.255.255.248 encapsulation frame-relay no fair-queue
R4 interface Serial1/0 ip address 10.12.16.4 255.255.255.248 encapsulation frame-relay no dce-terminal-timing-enable no fair-queue
R5 interface Serial1/0 ip address 10.12.16.5 255.255.255.248 encapsulation frame-relay no dce-terminal-timing-enable no fair-queue
from what ive read, this configuration is correct. let me know if you have any other configuration changes you would recommend.
thanks.
SPC Franklin, John Jay Network Operations
4IBCT, 1ID FOB Falcon, Iraq
Why you don't define DLCI on R3, R4, and R5?
Good luck,
Mike CCNP, CCDP, CCSP, Cisco Voice, MCSE W2K, MCSE+I, Security+, etc. CCIE R&S (in progress), CCIE Voice (in progress)
------ Headset Adapters for Cisco IP Phones
well shouldnt the status on the circuits be Active? They are all showing inactive as of now. would the map statements on the spoke routers help solve the issue?
Thanks!
The "active" state means that circuit is ESTABLISHED between "local" and "remote". So, if your "remote" is not connected, DLCI will be "inactive".
Good luck,
So with my configuration, the remote would be connected therefore the the dlci active. Am I correct with this statement? AFAIK, my configuration should work.. yes?
Thanks.
4th IBCT, 1ID FOB Falcon, Iraq
I determined the issue to be a bad NM-4A/S module in one of my routers. Everything is working correctly now.
Thanks!
