dot1x, radius and telnet authentication
Oct 31, 2006 2 Replies
Hi, i have setup radius dot1x authentication following guides online. However i can no longer login with telnet to the switch, i do not have the correct password (however before enabling dot1x the cisco/Cisco username/password worked).
How can i get telnet to authenticate against the username/password cisco/Cisco whilst authorising ports with dot1x control. My config is below:
! version 12.1 no service pad service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname Switch ! aaa new-model aaa authentication dot1x default group radius enable secret 5 $1$YeRS$MJ5UC5OFLc6HxqfyC7PVP/ enable password Cisco ! ip subnet-zero ! ! spanning-tree mode pvst no spanning-tree optimize bpdu transmission spanning-tree extend system-id dot1x system-auth-control ! ! ! ! interface FastEthernet0/1 spanning-tree portfast ! interface FastEthernet0/2 spanning-tree portfast ! interface FastEthernet0/3 spanning-tree portfast ! interface FastEthernet0/4 spanning-tree portfast ! interface FastEthernet0/5 spanning-tree portfast ! interface FastEthernet0/6 spanning-tree portfast ! interface FastEthernet0/7 spanning-tree portfast ! interface FastEthernet0/8 switchport mode access dot1x port-control auto spanning-tree portfast ! interface FastEthernet0/9 spanning-tree portfast ! interface FastEthernet0/10 spanning-tree portfast ! interface FastEthernet0/11 spanning-tree portfast ! interface FastEthernet0/12 switchport mode trunk ! interface Vlan1 ip address 192.168.0.1 255.255.255.0 no ip route-cache ! ip http server radius-server host 192.168.0.10 auth-port 1812 acct-port 1813 key test radius-server retransmit 3 ! line con 0 exec-timeout 0 0 line vty 0 4 password cisco line vty 5 15 password cisco ! ! end
Thanks,
Chris
Add the following to your config.
aaa authorization exec default none
Scott
Sorry this is what you need
aaa authentication login default line
Scott
