dot1q vlan question
Mar 22, 2007 1 Replies
In the following specific scenario Switch A port X connects to switch B port Y port A is configured with the following commands switchport access vlan 2
port Y uses default port setting (no specific vlan configuration)
Is my understanding correct? 1. ingress of port X adds the vlan tag to incoming frame 2. egress of port X strips the vlan tag from outgoing frame
Thanks
tagging only happens on trunks. port x and port y are access links hence no tagging happens at all.
