DHCP in a vlan over trunk on C2950
Mar 16, 2006 1 Replies
I want to connect a linux box to a cable modem. The modem is on a C2950, the linux machine is on a different C2950. Modem and PC are both in the same vlan, and trunking is enabled for this vlan. However the linux pc cannot get a DHCP address from the modem.
Before I had this configuration, modem and pc were on the same switch, which worked fine. Now it seems that broadcasting is not working across switches. Is this correct? Is there anything I have to configure? I read the O'Reilly "IOS in a nutshell" book and searched the web but couldn't find anything.
-Stephan Walter
Broadcasts are sent to any port belonging to the same VLAN including trunks.
How did you test that VLAN trunking is working ?
see
