Content Engine 590
Jul 23, 2005 3 Replies
Jump to replies (3)
Content Engine 590 open original image
Hello!
I am trying to configure a Content Engine 590 that was recently given to me. I do not know the reason why this device was retired before being given to me. So, I may be chasing a ghost. But, until I can confirm a hardware failure of some sort, I am sure it can be made to work.
Here is the console output when I boot it up. I have tried *** for recovery and without. I get the same results either way. At the bottom, it starts complaining of disk errors. Just before it shows the disk erors, it prompts for a username, but will not accept input. I would appreciate help on this matter as I need to get this working quickly.
Thanks! Jodie
Initializing memory. Please wait. BIOS Version: CE500 01.11 BIOS Build date: 07/27/00 Symbios, Inc. SDMS (TM) V4.0 PCI SCSI BIOS, PCI Rev. 2.0, 2.1 Copyright 1995, 1998 Symbios, Inc. PCI-4.11.00
HBA ID LUN VENDOR PRODUCT REV SYNC WIDE INT13 CYL/ HD/SEC
--- -- --- -------- ---------------- ---- ---- ---- ----- ------------ 0 0 0 IBM DDYS-T18350M S80D 80.0 16 BOOT 1024/255/63 0 1 0 IBM DDYS-T18350M S80D 80.0 16 81h 1024/255/63 0 7 0 Symbios SYM53C895 0002 80.0 16
Symbios, Inc. PCI boot ROM successfully installed! Cisco CE Booting From Flash. [BOOT-ASM] [BOOT-PHASE2]: entered [BOOT-PHASE2]: build date: Wed May 30 10:03:59 PDT 2001, build number 1 [BOOT-PHASE2]: directory verified ok [BOOT-PHASE2]: examining phase3 boot-rom: 'default_bootrom' [BOOT-PHASE3]: entered [BOOT-PHASE3]: version 1, built Wed May 30 10:03:59 PDT 2001 [BOOT-PHASE3]: directory verified ok timeoutHASE3]: enter `***' for rescue image: *** [BOOT-PHASE3]: default system image is 78 sectors [BOOT-PHASE3]: loaded 78 device sectors to 0x2000000! [BOOT-PHASE3]: extracting system image at 0x2000000 [BOOT-PHASE3]: loading kernel [BOOT-PHASE3]: system image header: v=2, b=893827, i=9219641 [BOOT-PHASE3]: rd set at 0x6000000, len 9219641 [BOOT-PHASE3]: moving 3072 code bytes to 0x90000 [BOOT-PHASE3]: checksum of relocated ramdisk (6000000) is
2a5dc12f17f3ead14c1a2439392c8a2f [BOOT-PHASE3]: invoking kernel now [BOOT-PHASE2]: booting kernel Linux version 2.3.36.csco (bbalagot@vista2) (gcc version egcs-2.91.66
19990314/Linux (egcs-1.1.2 release)) #1 SMP Wed May 30 09:54:51 PDT
2001 setup.c: E820 fixup: old map: 5 entries; new map: 7 entries e820: 0009ec00 @ 00000000 (usable) e820: 00001400 @ 0009ec00 (reserved) e820: 0001f800 @ 000e0800 (reserved) e820: 00e00000 @ 00100000 (usable) e820: 00100000 @ 00f00000 (reserved) e820: 3f000000 @ 01000000 (usable) e820: 00100000 @ fff00000 (reserved) Scan SMP from 7c000000 for 1024 bytes. Scan SMP from 7c09fc00 for 1024 bytes. Scan SMP from 7c0f0000 for 65536 bytes. Scan SMP from 7c09ec00 for 4096 bytes. setup.c: reserved bootmem for INITRD_START = 0x6000000, INITRD_SIZE =
9219641 mapped APIC to ffffe000 (01000000) On node 0 totalpages: 00040000 zone(0): 4096 pages. zone(1): 258048 pages. zone(2): 0 pages. Detected 598412973 Hz processor. Console: colour *CGA 15x25 Calibrating delay loop... 596.38 BogoMIPS kdb version 1.3 by Scott Lurndal. Copyright SGI, All Rights Reserved Memory: 1015056k/1048576k available (1596k kernel code, 32104k reserved, 181k data, 388k init, 0k highmem) Buffer-cache hash table entries: 65536 (order: 6, 262144 bytes) Page-cache hash table entries: 262144 (order: 8, 1048576 bytes) Pentium-III serial number disabled. Checking 386/387 coupling... OK, FPU using exception 16 error reporting. Checking 'hlt' instruction... OK. POSIX conformance testing by UNIFIX Pentium-III serial number disabled. per-CPU timeslice cutoff: 50.03 usecs. CPU0: Intel Pentium III (Coppermine) stepping 03 SMP motherboard not detected. Using dummy APIC emulation. Initializing CPU#0 calibrating APIC timer ... ...... CPU clock speed is 598.4278 MHz. ...... host bus clock speed is 0.0000 MHz. cpu: 0, clocks: 0, slice: 0, nr: 1. CPU0 Setting commenced=1, go go go PCI: PCI BIOS revision 2.10 entry at 0xe9b9c PCI: Using configuration type 1 PCI: Probing PCI hardware PCI: Cannot allocate resource region 2 of device 00:0d.0 PCI: Cannot allocate resource region 2 of device 00:0e.0 PCI: Allocation of memory region 00:0d.0/2 (-1609564160 bytes) failed PCI: Allocation of memory region 00:0e.0/2 (-1609564160 bytes) failed Limiting direct PCI/PCI transfers. Linux NET4.0 for Linux 2.3 Based upon Swansea University Computer Society NET3.039 skb_init: memory pools configured to steal max 150994944 bytes (144MB) for skbuff memory skb_init: pool locking done by local_irq_save/local_irq_restore, 4 CPUs NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (established 65536 bind 65536) Starting kswapd v1.6 Serial driver version 4.91 (1999-11-17) withKeyboard timeout[2] Keyboard timeout[2] MANY_PORTS SHARE_IRQ SERIAL_PCI PCI_IOMEM enabled ttyS00 at 0x03f8 (irq = 4) is a 16550A ttyS01 at 0x02f8 (irq = 3) is a 16550A pty: 256 Unix98 ptys configured Linux video capture interface: v1.00 DIAMOND-RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize DIAMOND-RAMDISK: Found compressed initrd image DIAMOND_RAMDISK: compressed_read: ramdisk md5sum:
2a5dc12f17f3ead14c1a2439392c8a2f DIAMOND-RAMDISK: allocate_ramdisk_space [rd 0]: map is 0x828f0000 DIAMOND-RAMDISK: diamond_crd_load (end):
2a5dc12f17f3ead14c1a2439392c8a2f DIAMOND-RAMDISK: compressed_free called! DIAMOND-RAMDISK: compressed_free: NOT CALLING free_initrd_mem! DIAMOND-RAMDISK: diamond_rd_init returns Uniform Multi-Platform E-IDE driver Revision: 6.21 PIIX4: IDE controller on PCI bus 00 dev 39 PIIX4: not 100% native mode: will probe irqs later ide0: BM-DMA at 0xfc00-0xfc07, BIOS settings: hda:pio, hdb:pio ide1: BM-DMA at 0xfc08-0xfc0f, BIOS settings: hdc:pio, hdd:pio Floppy drive(s): fd0 is 1.44M, fd1 is 1.44M FDC 0 is a post-1991 82077 sym53c8xx: at PCI bus 0, device 15, function 0 sym53c8xx: setting PCI_COMMAND_PARITY...(fix-up) sym53c8xx: 53c895 detected with Symbios NVRAM sym53c895-0: rev 0x2 on pci bus 0 device 15 function 0 irq 5 sym53c895-0: Symbios format NVRAM, ID 7, Fast-40, Parity Checking sym53c895-0: initial SCNTL3/DMODE/DCNTL/CTEST3/4/5 = (hex)
07/4e/a0/01/00/24 sym53c895-0: final SCNTL3/DMODE/DCNTL/CTEST3/4/5 = (hex)
07/4e/80/00/08/24 sym53c895-0: on-chip RAM at 0xa0081000 sym53c895-0: resetting, command processing suspended for 2 seconds sym53c895-0: restart (scsi reset). sym53c895-0: enabling clock multiplier sym53c895-0: Downloading SCSI SCRIPTS. scsi0 : sym53c8xx - version 1.5g scsi : 1 host. sym53c895-0: command processing resumed Vendor: IBM Model: DDYS-T18350M Rev: S80D Type: Direct-Access ANSI SCSI revision: 03 Detected scsi disk sda at scsi0, channel 0, id 0, lun 0 Vendor: IBM Model: DDYS-T18350M Rev: S80D Type: Direct-Access ANSI SCSI revision: 03 Detected scsi disk sdb at scsi0, channel 0, id 1, lun 0 sym53c895-0-: tagged command queue depth set to 4 sym53c895-0-: tagged command queue depth set to 4 scsi : detected 2 SCSI disks total. sym53c895-0-: WIDE SCSI (16 bit) enabled. sym53c895-0-: FAST-40 WIDE SCSI 80.0 MB/s (25 ns, offset 31) SCSI device sda: hdwr sector= 512 bytes. Sectors= 35843670 [17501 MB] [17.5 GB] sym53c895-0-: WIDE SCSI (16 bit) enabled. sym53c895-0-: FAST-40 WIDE SCSI 80.0 MB/s (25 ns, offset 31) SCSI device sdb: hdwr sector= 512 bytes. Sectors= 35843670 [17501 MB] [17.5 GB] eepro100.c:v1.09j 7/27/99 Donald Becker
: Intel PCI EtherExpress Pro100 at 0xbc804000, 00:30:85:87:5B:00, IRQ 9. Board assembly 668081-002, Physical connectors present: RJ45 Primary interface chip i82555 PHY #1. General self-test: passed. Serial sub-system self-test: passed. Internal registers self-test: passed. ROM checksum self-test: passed (0x04f4518b). Receiver lock-up workaround activated. eth1: Intel PCI EtherExpress Pro100 at 0xbc806000, 00:30:85:87:5B:01, IRQ 10. Board assembly 668081-002, Physical connectors present: RJ45 Primary interface chip i82555 PHY #1. General self-test: passed. Serial sub-system self-test: passed. Internal registers self-test: passed. ROM checksum self-test: passed (0x04f4518b). Receiver lock-up workaround activated. eepro100.c:v1.09j 7/27/99 Donald Becker
check: sda: sda1 sda2 sda3 sda4 sdb: sdb1 Cisco ContentEngine Flash Driver Version 0.01 wccp: v1.00 (20000327), debug=0 wccp_list_bypass v1.0.0 wccp_list_bypass tuple allocated 20480 DIAMOND-RAMDISK: drd_open called w/ dev 0x0 EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). Freeing unused kernel memory: 388k freed INIT: version 2.78 booting Content Engine application software initializing Mounting non-disk filesystems Set clock: Sat Jul 23 21:31:19 EDT 2005 Loading kernel module ipchains.o Upping loopback interface setting $TERM to vt100 set /proc/sys/fs/file-max to 65536 set /proc/sys/net/ipv4/ip_local_port_range to 10000 61000 set /proc/sys/kernel/shmmax to 268435456 set /proc/sys/net/core/rmem_max to 131072 set /proc/sys/net/core/wmem_max to 131072 calculated checksum: 38c9506fcbacd339d1d22a0c59778552 embedded md5sum : 00000000000000000000000000000000 calculated eth0 mac: 00:30:85:87:5b:00 embedded eth0 mac : 00:30:85:87:5b:00 other cookie info: HWVersion: 12 PartNumber: 128 0 133 121 1 BoardRevision: 2 SerialNumber: 83 67 75 48 53 48 51 48 48 56 87 TestDate: 19-2-2001 ChipRev: 176 ModelNum: 67 69 53 57 48 VendID: 2 CookieVer: 2 ExtModel: Chksum: 0x3f INIT: Entering runlevel: 3 Entering non-interactive startup Starting cron daemon: [ OK ]
Cisco Content Engine Console
Partition disk00/00 identified as SWFS disk00/00 has minor problem, but fixed. Return code = 1 Partition disk00/01 identified as SYSFS disk00/01 has minor problem, but fixed. Return code = 1 Partition disk00/02 identified as MEDIAFS disk00/02 has minor problem, but fixed. Return code = 1 Partition disk00/03 identified as CFS Partition disk01/00 identified as CFS disk02 is missing. Host: 0, Channel: 0, Scsi ID: 8 disk03 is missing. Host: 0, Channel: 0, Scsi ID: 9 disk04 is missing. Host: 0, Channel: 0, Scsi ID: 10 disk05 is missing. Host: 0, Channel: 0, Scsi ID: 11 disk06 is missing. Host: 0, Channel: 0, Scsi ID: 12 disk07 is missing. Host: 0, Channel: 0, Scsi ID: 13 disk00 (scsi host 0, channel 0, id 0) disk01 (scsi host 0, channel 0, id 1) disk02 (scsi host 0, channel 0, id 8) NOT available disk03 (scsi host 0, channel 0, id 9) NOT available disk04 (scsi host 0, channel 0, id 10) NOT available disk05 (scsi host 0, channel 0, id 11) NOT available disk06 (scsi host 0, channel 0, id 12) NOT available disk07 (scsi host 0, channel 0, id 13) NOT available Mounting disk00/00 as SWFS ...succeeded Mounting disk00/01 as SYSFS ...succeeded Mounting disk00/02 as MEDIAFS ...succeeded Disk configuration is initialized
Hi Jodie,
You may want to try:
username: admin
password: default
Sincerely,
Brad Reese BradReese.Com Cisco Repair Service Experts
1293 Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 U.S. Toll Free: 877-549-2680 International: 828-277-7272 Website:
Hi Brad,
Thanks for your response. What I meant by not accepting any input is that when I enter admin as the username and , nothing happens. It never even prompts for the password. In fact, if I am not quick enough to enter admin, the disk errors will start and then I really cannot do anything. However, even if I enter admin before the disk errors, nothing happens.
Thanks! Jodie
Jodie,
Your post above states,
"Symbios, Inc. PCI boot ROM successfully installed! Cisco CE Booting From Flash."
The Cisco 590 Field Notice states,
"Your CDN device may have been configured to boot from flash instead of from disk.
The CDN software must be booted from disk.
Some CE-590-CDNs were shipped from manufacturing with the flag set to boot from flash instead of from disk.
The CDN software needs to be loaded from disk.
Manufacturing has since rectified this problem, however some units in the field may be configured to boot from flash."
Cisco 590 Support Documentation:
Brad Reese
