connect lynksys rvl200 to cisco concentrator in IPSEC ?
Oct 03, 2007 0 Replies
Hi
i want connect a Linksys RVL200 to a cisco concentrator (3005) in ipsec
but i have a problems, the phase 2 don't start .. and i have this logs:
on linksys:
Oct 3 14:39:16 172.20.10.250 #warn VPN Log: [Tunnel Negotiation Info] >>> Initiator Send Main Mode 1st packet Oct 3 14:39:16 172.20.10.250 #warn VPN Log: Received Vendor ID payload Type = [draft-ietf-ipsec-nat-t-ike-03] Oct 3 14:39:16 172.20.10.250 #warn VPN Log: Ignoring Vendor ID payload [4048b7d56ebce885...] Oct 3 14:39:16 172.20.10.250 #warn VPN Log: [Tunnel Negotiation Info] > Initiator send Main Mode 3rd packet Oct 3 14:39:16 172.20.10.250 #warn VPN Log: Ignoring Vendor ID payload Type = [Cisco-Unity] Oct 3 14:39:17 172.20.10.250 #warn VPN Log: Ignoring Vendor ID payload Type = [XAUTH] Oct 3 14:39:17 172.20.10.250 #warn VPN Log: Ignoring Vendor ID payload [a95027b32eb5797c...] Oct 3 14:39:17 172.20.10.250 #warn VPN Log: Ignoring Vendor ID payload [1f07f70eaa6514d3...] Oct 3 14:39:17 172.20.10.250 #warn VPN Log: [Tunnel Negotiation Info] > Initiator Send Main Mode 5th packet Oct 3 14:39:17 172.20.10.250 #warn VPN Log: Received Vendor ID payload Type = [Dead Peer Detection] Oct 3 14:39:17 172.20.10.250 #warn VPN Log: [Tunnel Negotiation Info] >>> Initiator Receive Main Mode 6th packet Oct 3 14:39:17 172.20.10.250 #warn VPN Log: [Tunnel Negotiation Info] Main Mode Phase 1 SA Established Oct 3 14:39:17 172.20.10.250 #warn VPN Log: [Tunnel Negotiation Info] >>> Initiator send Quick Mode 1st packet Oct 3 14:39:17 172.20.10.250 #warn VPN Log: received Delete SA payload: deleting ISAKMP State #526
Cote Cisco (en face)
***31 10/03/2007 12:39:43.030 SEV=5 IKE/172 RPT=49953 xx.xx.xx.xx * Group [xx.xx.xx.xx] Automatic NAT Detection Status: Remote end is NOT behind a NAT device This end is NOT behind a NAT device
35 10/03/2007 12:39:43.130 SEV=4 IKE/119 RPT=26035 xx.xx.xx.xx * Group [xx.xx.xx.xx] PHASE 1 COMPLETED
*36 10/03/2007 12:39:43.130 SEV=6 IKE/121 RPT=17102 xx.xx.xx.xx * Keep-alive type for this connection: DPD
37 10/03/2007 12:39:43.130 SEV=4 AUTH/22 RPT=26055 xx.xx.xx.xx * User [xx.xx.xx.xx] Group [xx.xx.xx.xx] connected, Session Type: IPSec/LAN-to-LAN
*40 10/03/2007 12:39:43.400 SEV=5 IKE/35 RPT=16111 xx.xx.xx.xx * Group [xx.xx.xx.xx] Received remote IP Proxy Subnet data in ID Payload: Address 172.20.10.0, Mask 255.255.255.0, Protocol 0, Port 0
43 10/03/2007 12:39:43.400 SEV=5 IKE/34 RPT=4496 xx.xx.xx.xx * Group [xx.xx.xx.xx] Received local IP Proxy Subnet data in ID Payload: Address 192.168.200.10, Mask 255.255.255.255, Protocol 0, Port 0
*48 10/03/2007 12:39:43.400 SEV=4 IKEDBG/97 RPT=62505 xx.xx.xx.xx * Group [xx.xx.xx.xx] QM FSM error (P2 struct &0x144beee4, mess id 0x7ddaff3b)!
49 10/03/2007 12:39:43.400 SEV=6 IKE/1 RPT=58250 xx.xx.xx.xx * Group [xx.xx.xx.xx] Removing peer from correlator table failed, no match!
*50 10/03/2007 12:39:43.400 SEV=4 AUTH/23 RPT=31907 xx.xx.xx.xx * User [xx.xx.xx.xx] Group [xx.xx.xx.xx] disconnected: duration: 0:00:00
anyone know where is the problems ?
