CiscoVPN?
Mar 31, 2006 1 Replies
ciscodagama
Here is a list of ports that seem to be relevant and that you can open to experiment UDP port 500 (IKE, Internet Key Exchange) IP Protocol 50 (ESP) IP Protocol 51 (AH) UDP port 10000 (IPSec encapsulated in UDP) TCP port 443 (IPSec encapsulated in TCP) UDP port 62515 UDP port…
CiscoVPN? open original image
Hello,
A company that we work with have given us their cicoVPN client to get into their system. We have a sonicwall at our end. Out sonicwall has all outgoing allowed but strict rules for incoming. What ports do we need to open for incoming to get the ciscoVPN to work from our end?
Thanks
UDP port 500 (IKE, Internet Key Exchange) IP Protocol 50 (ESP) IP Protocol 51 (AH) UDP port 10000 (IPSec encapsulated in UDP) TCP port 443 (IPSec encapsulated in TCP) UDP port 62515 UDP port 4500
You should experiment a bit and see what the minimum list is for VPN to work for your set-up.
Cisco da Gama
