Cisco ip helper-address
Sep 20, 2007 10 Replies
Jump to replies (10)
Cisco ip helper-address open original image
Hi
I had pass the 4 CCNA curriculum sessions successfully and i'm not able to do something I think is basic.
I have to forward PPPoE Broadcast packets to my PPPoE server at 10.0.0.2 over my Cisco router.
I use the Cisco 851-K9 router and read on Cisco session 4 that the ip helper-address command forward the Broadcast packets to Unicast IP address.
So I've put in the int Vlan1 the command
ip helper-address 10.0.0.2
and that doesn't work.
I see something about the ip forward-protocol command but I think I missed something.
If someone can help me, It's will be appreciated.
Best Regards
Martin
ip helper-address only operates on UDP packets
Are PPPOE packets carried in UDP ?
Suggest you take the time to understand the PPPOE protocol.
Take at look at the PPOE overview @
Make sure you understand the payload contents i.e the various fields in the payload
Also make sure you understand the stages of a PPPOE session.
Hi and thanks for your answer.
After your recommendation I read the PPPoE documentation:
and the RFC
I read on the page #2 in the RFC that the Ether_Type for the discovery stage is 0x8863 and the PPP session stage is 0x8864.
Nowhere they talk about the UDP Protocol and the PPPoE Broadcast.
I'm confuse
So I had try with ip forward-protocol any-local-broadcast, doesn't work.
I had enable the debug on the udp query, I dont see anything
I had enable the debug on all the query, very big mess to check
I'm sure that all ISP using the PPPoE user control use a complete routed network behind the PPPoE users sessions.
Otherwise, it's doesn't make sens.
Can you help me please?
Regards
Martin
"Merv" a écrit dans le message de news: snipped-for-privacy@k79g2000hse.googlegroups.com...
So by reading the RFC's you have confirmed that PPPOE does not use UDP
- that is correct.
Thus forget about the ip helper-address command as that is not the solution.
Is this an exercise or a question that is part of your CCNA curriculum or just something you are trying to figure out ?
ISP networks are definitely routed networks at least at the edge and typically these days label-switched in the core (MPLS).
The first sentence from
: "PPP over Ethernet (PPPoE) provides the ability to connect a network of hosts over a simple bridging access device to a remote Access Concentrator"
look very carefully at the sentence ...
layer 2 or layer 3 ???
Layer 2.
mmmmmm......
In fact, this is not an exercice. I have to do it!
Sorry but what do you means in this sentence:
"label-switched in the core (MPLS)."
Regards
Martin
"Merv" a écrit dans le message de news: snipped-for-privacy@o80g2000hse.googlegroups.com...
It is possible to talk with you out of these Forum?
Martin
Hey, my light are turn on now ....
New question
How can I bridge Cisco Interfaces? Put it in the same Vlan?? Specials Commands?
Regards
Martin
Hi and thanks for your light!!!!
At the section Transparent Bridging I found this sentence
"Provides the ability to bridge over X.25, Frame Relay, Switched Multimegabit Data Service (SMDS), and Point-to-Point Protocol (PPP) networks."
PPPoE, as I read in the Rfc doc is a part of PPP but only the transport frame is different.
I will try this Very, very, very best regards.
Mart>> Hi and thanks for your answer.
yes it needs to be bridged as there is no IP information in the PPOE Active Discovery packet
So are you trying to setup a PPPOE server in a production network ?
It will help responder if you provide all of the background information on what you need to accomplish.
Also take a look at RFC 3817 Layer 2 Tunneling Protocol (L2TP) Active Discovery Relay for PPP over Ethernet (PPPoE)
Hi Merv,
Youre right and I will glad to give you all the background but not in the Forum.
Can I send you personal Email to your rogers Email address please?
Regards
Martin "Merv" a écrit dans le message de news: snipped-for-privacy@50g2000hsm.googlegroups.com...
