Help Understanding IP Helper
Jul 15, 2006 2 Replies
There is obviously something about ip helper I do not understand. Perhaps someone could explain.
My understanding is that when ip helper 192.168.1.2 is placed on an interface it will forward the following upd brodcasts to the address specified:
TFTP (69) DNS(53) Time(37) Netbios name Service (137) Netbios Datagram (138) Bootp Server (67) Bootp Client (68) TACAS (49)
I did not think that dns or tftp, for example, are broadcasts. Could someone explain what a dns broacast is? In both dns and tftp the client specifies an ip address. doesn't that make them unicast?
Thanks
I think Macs use broadcast DNS as part of their "Rendezvous" mechanism.
Broadcast TFTP is used by netbooting devices. In fact, Cisco routers themselves will send out a broadcast TFTP request for their config file.
That's a question about what applications use broadcast. What question did you have about the "ip helper-address" configuration? :)
Thanks for the insight Barry. I think I understand how to configure ip-helper. I have an application that required it. I need to allow dhcp broadcasts to forward from one subnet to another. I configured ip-helper address on one interface of the router pointing to the dhcp server on the other subnet. Since I had an acl on the same interface as the ip-helper address that only permitted telnet, I had to add permit upd any any eq 67 to the acl.
Thanks again.
