Cisco Catalyst 3550 causes "Excessive jabbering" on HP switches
Sep 20, 2005 6 Replies
Most relevant reply
anybody43
A jabber is a long frame and the cisco is capable of sending "trunk" frames that are longer than normal. By default the cisco will try to negotiate various cisco specific and non-cisco specific port options. I suggest that you turn off the ones you dont need. See:- may need to…
Cisco Catalyst 3550 causes "Excessive jabbering" on HP switches open original image
Hi
We are running Cisco Catalyst 3550 as core switches. We are using HP procurve as edge switches, mainly 2524 and 2650. Im having intermittent disconnection problems which seemed to originate from the Cisco box. The HP switch will report "Excessive jabbering" on the port connected to the Cisco. At the same time the Cisco log shows that the Interface connected to the HP has changed state from up to down but no errors. This will last around 3012 ms before the cisco changes the interface state to UP. This is intermittent and may do it several times in one day and nothing the next. I have the same problem over a number of remote sites, all same setup and config.
I have swapped the CISCO with a HP 2824 at one site and this has eliminated the problem at one site. However i dont have anymore cash to replace the other sites.
Thing I have tried:
  • Changed transceivers and patch leads on both Cisco and HP
  • Set all ports on HP to "no lacp" - didnt help
  • Disabled spanning-tree on Cisco - didnt help
  • Turning CDP off on cisco - didnt work
  • No error disable all on cisco - didnt work
  • VTP mode transparent on cisco - didnt help
  • Storm control for broadcast, multicast and unicast on cisco - didnt help
Here are the standard running configs of Cisco
! ! Last configuration change at 13:31:56 AEST Fri Sep 16 2005 ! NVRAM config last updated at 12:09:58 AEST Fri Sep 16 2005 ! version 12.1 no service pad service timestamps debug datetime msec localtime service timestamps log datetime msec localtime no service password-encryption service sequence-numbers ! hostname QBCG01 ! enable secret 5 ******* enable password ***** ! clock timezone AEST 10 clock summer-time AEST recurring 4 Sun Oct 2:00 4 Sun Mar 2:00 ip subnet-zero ! ip domain-name illawarra.det.win ip name-server 172.25.80.14 cluster enable QBCluster01 0 ! ! spanning-tree mode pvst spanning-tree extend system-id no spanning-tree vlan 1 ! ! ! interface GigabitEthernet0/1 switchport mode dynamic desirable no ip address ! interface GigabitEthernet0/2 switchport mode dynamic desirable no ip address ! interface GigabitEthernet0/3 switchport mode dynamic desirable no ip address ! interface GigabitEthernet0/4 switchport mode dynamic desirable no ip address ! interface GigabitEthernet0/5 switchport mode dynamic desirable no ip address shutdown ! interface GigabitEthernet0/6 switchport mode dynamic desirable no ip address shutdown ! interface GigabitEthernet0/7 switchport mode dynamic desirable no ip address shutdown ! interface GigabitEthernet0/8 switchport mode dynamic desirable no ip address shutdown ! interface GigabitEthernet0/9 switchport mode dynamic desirable no ip address shutdown ! interface GigabitEthernet0/10 switchport mode dynamic desirable no ip address shutdown ! interface GigabitEthernet0/11 switchport mode dynamic desirable no ip address ! interface GigabitEthernet0/12 switchport mode dynamic desirable no ip address ! interface Vlan1 ip address 172.25.80.201 255.255.254.0 ! ip default-gateway 172.25.80.1 ip classless ip http server ! ip access-list extended CMP-NAT-ACL dynamic Cluster-HSRP deny ip any any dynamic Cluster-NAT permit ip any any
***** Here is log from cisco
abitEthernet0/3, changed state to down
000279: Sep 14 18:22:29.074: %LINEPROTO-5-UPDOWN: Line protocol on Interface Gig
Here is running config of HP
; J4813A Configuration Editor; Created on release #F.05.34
hostname "QBH103" snmp-server contact "Network Administrator ICTS Dapto 4221 6478 " snmp-server location "Queanbeyan AG-1B" time timezone 600 time daylight-time-rule Southern-Hemisphere cdp run ip default-gateway 172.25.80.1 ip timep manual 153.107.37.21 snmp-server community "*********" Unrestricted snmp-server community "*********" snmp-server host 172.17.66.92 "public" snmp-server host 172.17.67.86 "public" vlan 1 name "DEFAULT_VLAN" untagged 1-26 ip address 172.25.80.204 255.255.254.0 ip igmp exit stack commander "Queanbeyan-AG1B" stack member 1 mac-address 0008833f1580 no aaa port-access authenticator active spanning-tree password manager
****** This is the error generated from HP
W 09/14/05 18:23:30 FFI: port 25-Excessive jabbering. See Help
Probably it will mean no difference, but why not to use:
switchport mode trunk switchport trunk encapsulation dot1q
-as
Looks like you're doing only 1 VLAN. Maybe the cisco wants to negotiate trunking.
try: switchport mode access on ports that are connected to HP.
See:-
you may need to translate it slightly for your platform.
As suggested:-
Is a VERY good idea. This will turn off trunk negotiation.
The following command shows the trunking status of the port. My guess is that the port is coming up as a trunk.
CORE2#sh interfaces gigabitEthernet 1/2 switchport Name: Gi1/2 Switchport: Enabled Administrative Mode: trunk Operational Mode: trunk Administrative Trunking Encapsulation: dot1q Operational Trunking Encapsulation: dot1q Negotiation of Trunking: Off Access Mode VLAN: 1 (default) Trunking Native Mode VLAN: 11 (VLAN0011) Voice VLAN: none Administrative private-vlan host-association: none Administrative private-vlan mapping: none Administrative private-vlan trunk native VLAN: none Administrative private-vlan trunk encapsulation: dot1q Administrative private-vlan trunk normal VLANs: none Administrative private-vlan trunk private VLANs: none Operational private-vlan: none Trunking VLANs Enabled: 11,210,301 Pruning VLANs Enabled: 2-1001 Capture Mode Disabled Capture VLANs Allowed: ALL Unknown unicast blocked: disabled Unknown multicast blocked: disabled
You may also want to make sure that jumbo frames are off.
Just my words + No negotiate hth Martin
Thanks for your help everyone. I have tried switchport mode access and after several days there has been no further errors...not one on the entire network! Switchport mode access has soved the problem
Li5ubyBhaGl0LiBJIHNhdyBzb21ldGhpbmcgbGlrZSB0aGF0IG9uIGFuIGhwIGpLw7bDiARTwrR+ YHN3aXRjaArigJ4kFDnDpDrCssOjKnFYw7jDsTxFw6Iow6wTw4Maw43CpcOG4oC6EmpLw7bDiART wrR+YMWgQuKAsCBocCBzd2l0Y2hlcwphcmUgaW5z4oCgYgLCuT8uS8OtZAMkZAPCrh4dw5TDsD/D osKyw5bDs8Ocy4ZswrnDvwrDiXpZbMK8RsKBEsOPW8KxMSoFw515wqY0wrLCscO1LRzDkcKvw6TC oFczecOjHxLDj8Ktw4zFvh/DsMODw6rFoXDCthJbw4oZYRLCvsO0CuKEoh3DhsOGGMKdGiLigLrD lcKjUnIY4oCmwq/DvyAJJ8KPw77DgS3DrMOaCsK1wroJxaEPL8Osw7LDnDw/wr7igKZD4oCiRgoi y4bDnmzDrFwTCWDDhV1FIHXigJrDk8OFw7zDvyDDhMO3RMOrw78KQGl/w7kmwrgtO0lfy4bCvhnD sQbigJTCryTDlsK6wrXDpcOYwr4JJsW4JcK84oCTwqvCtWHigKBA4oCZEg7DoW5JCsOkYeKEoncD XRXCr+KAucO8RMO6dsKiw5rCt+KApiTDksKuw6EwR2bCrXbCs0dxJMOSy5zCkBdQCsO7N2DigJzC tMOnHOKCrHo9H0LCsMORY2/CsVrDhRTDkuKApsO7RMOlAeKAk8Oh4oCgfmkfCsK7EljigJM5JOKA mXvDkAcJwqLDq8WhwqR2w5J4K1vCtsK5xbhY4oCZw4DigLp5dTjigLlEw47DqylbecOkQsOLJ8OL Gx8xccK9VcKBCsOqQcK2wrF4w4rDosOew6dOw5N1ZcKzwrnCtcKw4oCgDF044oCTWGQfw7LDlcKz E3nDol3igJ4JQygB4oC6McO54oCYwrDCrS8dw7hGw7dbwoEvwrQr4oC6ax1+JWhjwr7igJkswr/C kMOg4oChxZI4BeKAnMKuQyjDnDkKwo3DrGvigJTDsOKAlMWSw6fDlsOsbTV9SWZdY0LigJjDtMO9 bVoPK8OL4oCaZh/Cv8OBw4BSHhjDi+KAmUBFWcW9w5A2w5AFw5s9G8Oiw5HCtcOywq7DvFPCoyzD jyjDvcOqw5rDr3XCjcWg4oCTYAxqwrvigJRmFUjDgcOzXywIXEce4oChw7F6K0lVwrxTwqRPNMKw bVLDkSoLeXzDkHcuCjvDh+KAk8K4w6QuC8W+PlBPwqsDxaHDpzxdwqpdacK6SsOFwqfigKDDvsOT wr/ihKJswqzLhkLDuyV/w7loQFbDuVEDw4hyMeKAniPCvQpRw5DDosK8w5VvbWbDlSZb4oChw5HD o0jCvMOYwr5Yw6bCvcOyw4pcSjAKZVDDpjHFkmHFksOB4oCUKsK4w6zCq+KAocOXfBNze2/CoVjD qRrDtcOu4oC5Y8KmwoEbR2rDsgbFoSUKFQss4oC5w5AuMnceScOjxZPDpcOfw7w2w7EFw6pswo/D oh7CuSBY4oCaJsOMwo/FkxVQw45D4oCaw78KwrtACMOPLlnDsjcVwqAOwrvDhOKAk1cXwrpqT8Kn wqfihKLCqFjDisK3dsKoCFMjJ1jDgx4Xw4xCw7HDrjwBITg4wq854oCcw4IXxaE8F14yw7AKFsKN dQLDncKdLsOiOXAKbmfCjRI3w5rDm8KBKhDCqyB5RlzigJo7G8Kow7UvCsOpxb4Kw5dnw5Uew7bD umtlaC3FkzLDmyTDiOKAulEiy4bCuSPDjHLCowHCssOEwoHDlsK6LSNOwo9Jw5IswrTDmHfCtDbC kEcEZkILFUUKCcOAAzgd4oKsw7oKCsOCw7B3xb0sPFdmWjUWwrfigJjigJNZbVpow5zCncucDyRl ScOzIsOeSuKAsAcExpJXPFchwrfDsMO1w43DucWhWOKAmcODZcOzGMO5Z1gdZWQdPsO6wqMuc8OR xb1BHFYPxZJ+Hn9uSnVtHsOyTTtfDMOyJMO/CmjFkyljAeKAuSAk4oKsRkgRZeKAnR/DtWMh4oCg QcKtw6HCj8uGw4nCql/DicKgw7jCp006NsKzG8O5ChTDrDzigLnCqTDihKJYw5jDtTnCkBDigqzC tlXigJ3igJrDmcKgD0gHNMK1w4zDuCcJw6FLO0DCpX7DgcK/TyfDu8Omw55GxpJ+OcOGw68vOMOJ w4Zx4oCcxZLDlyUm4oCUw7FgXzTDicKtaCYYw4t5UGDigKZhw6bDr8O9w6/DrgsRwrPDpMOCFDwp w45Bw5wBw6p1w4xqDMK+GsK94oCcV8OzB8OYwq9uYUvDpH42w4rDpQpJwpDDvwrDn8K1ZScbQGHi gJrCpEnDil5pxbgWwp3CsWPCr8Oow7HDhsORbD56w690bzdwbcOLCAx2YXPCtVcEw7zCuRvDj8Kj w5zDm8OFeQzCtsOzw4TigJnDgSoU4oCZKRdywrrigJjigJoIPBBGQQbigqwtw5ctFMaSw4TDuuKA psKlw7xz4oCgw5HCrR3FoSUEMl7DjAjDmydPwrjigKZJQ8ORy5zigKEcIjNmw4nCp8Ocwr7CuMOe HsKzw5VvX0lrQy3DvHcyGWTigKZcw6I4w6PihKLCv3nDu8OMTcK4wrFywqFwwqYyVMOXYWtrCsK0 EcObw4ESQwxoEjjDo1DCqsWgBgLigqw4IHYDwqUgcsO+JcOxXsK5wqRqccOZaV4Swr3DlgzCoi3C s0cwxaAKX8ONw4rCsxU4KiNTxb7FuD8lfl3DnMO0w74vw7jigKDigJM64oCmw4ReARPDm8Krw4zD tmzDlyjFvcKoD8Ouw7fDg8K54oSiw5xjJCkb4oCwAX1PwqpWbsKhwqvDqcO6QsOGw5fDt8KQW8O5 w43CtiXigJlAwq0rf3UXwqs3wrDDicKgDm9IwrjDscOUwrc2bcKoCivDrMKNOsKsw6IbV0YRGDfi gJQFwqYkES/DrsK24oCdw4/DsWAOBsO+wrfCpgpWw5I0SUw3UErCtxbDkwHCneKAmS9MxZLigJpU
4oCaVeKCrCMqw4wyM8WhwqEvwo10eEB5w4bCo2sWQGnCrsK0wqvCqGJMwpAyw47DseKAplHDjyTC kAdyKgvDrx7DuHYraQbFuMKsw6nFocKNw7nDuS3CrMKgwr7FksK8w7MSFSMYJxvLnMKow44wMknD oBoKw5XDkMO1E8Kpw6nDqyzDkeKAuXvCtCEuw613ZcKtw6bDgCzigJ7DscW+wqDGksWSMuKAomHC kMOAwp3FoMOiw6LCj1LDsMOewqU1w77Co3d7wqpaagVMw6IbQyHCtcucLjMaRsKlwrzigJNQF2/D jMOKw4AcwrbDt3HCqMK+KMK3xaEVa2sKWlkcwrhI4oC6T8WhEsOFQDgtKsKiwq5Bw6DCsyBPIOKA nMOFCnQVw4vDqsOXMV94wqNDwrHCtsWhOS7CrMKuHsO2w6IlYExxeRLDhgnDtCXCpVwDw5QGIztN ZsOIw7rFvcKrwq/Dh2fCr0FxwqZZTRDigJnDhW11F0bigJNMwrl04oCZSMO24oCYIsKmCMKNWMKp HmHDnMO7AU7Cp07Dk23CtMKrWMKtLMOhWMOgQcOAw6pJw4kly5zFvlnigLAk4oCTPOKAmUkk4oCc QBzigLl8VsOQwr/CtMOnw5MjwrbDlCTCveKAoVJtMMOGIlHihKLCvmDLnGLDmMODwrIywqkkcj5t wqPFocKqPjF4d8Otw5ZWw59kw5XCgcK9wrvDuzQywr3CsMW9NgfDiysmw6dhw7Iyw4rFkj/igLlp BOKCrArDp8ORfMKucljFuEpBEuKAoMOIJznDj8OUw5AHLcOiZGnCvEvDocKPwrHDmsObw5xqVsO3 E1zCjznCvMK9wrbDohbFvVIcKxHDs0sPw4oHw4x2w7YE4oC5F8KNw6JLO8KxcgrFvcKjYiRvMsOO w57DjMODccOlw6HigJrDrOKAmUnDtjMGK8WT4oCmBXdjxZMDLcOoB8OiDsKNw6vDveKAon5Bw78K wrbCtuKAosOPw6rDusOHw4RRf2tvwqPDuGrDjcKjw7tUw5HDnFxeSOKAmibigKHDjcOETsK7ZS4/ d8OLZUnDj0XDrUAacsObw7jigLlfwrbCnSbCuH0Gw5Jww5HLnMKiQMO3wqrCv8OeEyvCtHHCscO0 CsOkDsWSGMO8wq7DsQ7igLoO4oCiw6E4ZMKw4oCTKzXDkCNb4oC5RsucPOKAsBJE4oCmWVsZYgxF w5DFkzEBwrcgWArDpsKiw5TDvi1LAhPCoMOoUcOcFsuGO0jDhCLDpMK2w7A2w4rDheKAmsKN4oCe xb4OQwrCr8OBwqvFocK/4oCwwrTDjWfDg+KAlBobX8Krw6vDt2klwqLDmsObw4DDu8KkwrpAQ23F ksO9w6h3wqPigJrDjExEBlZiN1AGw5R+K8Whw7LDnMOHbcKhw6rDkF9KD8OZwqLCvMK1dMKNwrPD t13DpBlUXsKkwqsRJgcISVBj4oCUQ8OUw6/DtRhtwrXDmcKsw7UdGWPigJjDpMKNwqErw6bDjkri gJ0PFgrCtGgE4oC6csOHw68mQXjDhOKAocKswo/Cv8KtcVrDl8OEw40Lw4PDmsKkwrZ6woHFoTMV w6Q2bMO7wqPDhsOpIxIXw5vCv3figJPCgeKAlHNtw6DCsAM8w6ADZsOvw4PDiSbCoy7CqcKmw5w2 wp3CqcOKFWbFvjQMwrcBfsOqw4zigKHigKEDwoHigJjCtcOAw6FdQTnFoMOfw4QTWsOJFcKuwr1r HsKdeSssccOKJ1fCtsK5wpDFkwTigLDDjht3I8OldVY/NsOQw6FJwq5af8KNPh/FoMOKw4rDrGnD usKzw4N4FMOGw55MasKqCSoLwrs4VcOLJMKrw4nDvwrigJMufsOuGMO0xb4aw7E2wo3Do8O9EsOi w6rDiifFvsOAOcK2xaE7wqjigKAcy5zDkeKEokrDpOKAmgp9wqfCsSHCseKAmOKAmkA6xaHDpsO1 Lwtpw7PDg3M9xb3FuMKnw4HCq8K0chtbw4ktUcONwrzCrBjigKAZBwN7FgpwSzE5LHPCjWtxc8Kj w6rDslvDqMO24oCU4oCUw54d4oCaN1vCkBgyw5pI4oCmVEdqB8OPCl/FuHp8w4F2w6xDwrl8wqPC tMW+KsK2wp3FknbFoX7CsTzDo+KAmBNpw5PDgcK7xZLDo3zDisuGD8O7w4w/PAoKw4PigJpde8OB xaEUc8OrOsOVwp3DreKApsKtw4BL4oCww64R4oCTaVJJwrnCkMOIX2psEn/Cq8Oaw7kR4oKsGBbD gsOl4oC6wo1bUMKww7DDtsK1LMW+CsW+a+KAolvDu1TCtcK2wrXFocOSw555In3CscK6w61ZdmHD ihZmCjcCZFPDsw7igJRTw5Y1w4vCjRNQaz0ldOKEosOj4oCwwr/DknXigLnDiMKjxb01w5rDhMOJ y5xMwr93CkhtwrwewrxWC3jDocKtw6c6L+KAoCzCtMOJw60hwrMxw6nDlwp94oCeeRV2RxjCj2gl DOKCrEYkw5wjJ8Olw7M3w7zigJ0Be0vDsUvDqRpdwo3DtsKnFcWhw6jDl8OyZ8Otw7bCtsOPbMKw SSEkGWPDi8Kuw4Zsw77DvEhV4oC5wqnDhsOTwrzDtMWhw4bigKZtwq0kTMOPJcKtw6XCuwfCtsK9 woETw4/CtzvCgW3FksOKw5gKwrdrDGHigJ3CkHIKZ3hbw4PGkk7DsMKdwrbigLp9EOKAnMOP4oCe NcOdwrTigJhEwrEHdR5kYiQeWsKmc8OywqjDgSTigJlJJMWhN8Kxw4nDoMOIwq1sw7R7w7M8bxnF oMOHQ8K5csOSSlVwEgl5dQrCtljDiCRVGMOmNRkKGhB4TksoI8aSTsOxDsKvZxLCoA7CqcOkScOm w4nDhsOpW8OM4oCwwrDDrEZbbgFiWxvihKLigLDigLpCw7DDlDo6RMOyw53DncOfX8KsPlPDncOd XEsrc+KAmsObBMW9w5sUwpA4HXbCrksQCj4vE8OZwqXDhcK9wq7CpRTDulXDncOBw4RQw54FAcOY wrbDlUEiFsWSwrnDqhA5bHPFkldBQAUUVBJKwpDDhsOPIyrCouKAmsOMw4xwIB1JPuKAnQHigKbD oSUWw5psw7pGw6BbS8K5e0VFw44i4oCh4oChwoEyeuKAmAPDhAnDpMOnOSTDpMOWwr3DlcOUVnbD ksOcw47DqxxRI0jDrsON4oKswqoGSSTDsAfDl8OrXCJ4wqjDi8OjG8ODw6HCjTZ9VjvCuGJJxbji gLprSMOmRyDDiGVh4oCwC0UqNlAxKRR4w5zCreKAncK9wqXDuFfDhFc+VMK+IcOxZMOXTxfigJ3D vyBm4oCgw47Dm8OKWVdrMcOcw5DDvMOfOuKAmsKnasKyDjJPw41AEl7Dn8Oeal47w5BtbFnDocKz wrfDu2zDl8W+fFJCZsOY4oCwEFQlRsO1w506wrZ5U+KCrEEla1rDs8O+Sh7CjcO/IGDCq8O/IMO9 G2lSw4PDocO7K31gw6rCseKAueKAlMK8YSJuxb7DrllVVcOYM8KqIzlUBMKqw73DkD7DqB0qK8OP w7koejfDveKAmsKvw78gw7RtwqUgdBXDi3gZVGnFocKhCgFta1AnHcOPw5pkGcO9K8Kpwq5fw4Ek HSdRw4Yzw73CscKow6cDw77FvsKlw7zDqAPCqMKixaAoCsKixaAoA8OFw74BCMKiw5M1w7jCrUnF ocORb1PDicK4E+KAmSQFOnlHGxgMZcKwN2cDOyvCpipHw4fLhsOOw5Ufw7FNMMOOw6/LnMOiw6h1 GcOpw6hxw5zDunHDj8O8BjbDrcOhw5vDj8Kyw5vigJ0Ry5xjeUhTw6bCvsOWdsO5w4QISAXDiMOa w48hX2BUwr9Mw5AFw7jDnwrDhsOXw4vDuHZIw4nDo24Ww6UIA8K+fm57cj3DqAPCvMKsDw8Ma14q w6PDvmLigLDDvwrCpHbDlV5vHMOoNsK64oC5WMOdXcOLbz/DmsKjwrQCW1lQPMKyM8KqBSV+ZSYp BsOxw7LDvMK9a+KAsMK4w7HFvuKApnvDoMO/Ch3DqjbFocONwrRpwqhJcMK2LSzFvkvDjMOrYW7C pCLCthjCkMOccDrigJjDqigCfwx44oChw4QaP8ODHSNRfRLDo1XCv8K8a8KrwrnigKJDwqklw6V5 VwsUbnLDocKywr8oQcW+WXLCoMK1w74neMK3w63DlxbDsHwxw5YkSMWS4oC6ZGlZQ8KqAnIP4oCd VOKAmRfigqwYw6TDoArDhMWSw7V+CsOVdMKBwqDDqXolwrbCucKlw5/DnsOZWMOFFMKrZ3bigJnD pMKiKsKzDBzDrcOIw6pAw6tdbSB5HcO/CsOFw61XTMOSLm9vwrwKwqpbC3XCjcOzN8KdHCwbaCvD pjQDa8KrMBgKKcODYcKPw4obwqDDk8O+JMOZXMOow5rCrsKndWzDsSXFvcKpLuKEogQwOeKEosOv ZFA2COKAoMOQSz54XsOYw4k4w4kdbcO9w7Q6fcKswrdXDlIkw4ZIBeKAsCTigqwUCglmJOKCrBQC SSAgScKsTw9p4oCZw59ZacOaw6bCvRLCvsKxJAsgRsaSYsOZbkw0cSNkwqHDgSHFvXcxw454CsKq ASHFuMOF4oCUQMKiWGjDtipYwoE7w53DiXLDijt+w6hHGDkYH8OrBjPFvnHGkuKAosKlRcOixbgP w6nigJPigKDDrsObTuKAmQgdxbhQxb3DkcKlxaF5w55Nw48kw6hIQA/LnMObxZJhW8OlLBTDpCri gLrigJTCsHjCtcK8UwXDhcK04oCTwqdHScOVHsOXw44Kw48JTcKsw4VMJMOvV2LDgxIFKuKCrGMk 4oCcJsKBH+KAuWPCuEjDvEFxwqbDiMW+Q8K04oCgw5EYZmbihKLLhgpbHyLDh8KwD+KAneKAmXPi gJzDhwoPw5XDtS1Ow7PDgcKxasW+FsKBby/CpUgubVDCkMKrLGzDqMOMMyYxy5zDi3XDgcO6HFc5 w7bDvwrFoCZf4oCUSMORw6NTDGFGTMuc4oCdw7DDm8O/CnzCoWPDisKzZUMwV0HCtcW9w63CusO2 wqHCvCvDogbDk8OgwrBowrQrw6figKHDrMOyw4YjWC0uGDhow7bDrgY0YuKAmOKAogFIMkzDnMOl 4oKswq7DkuKCrDgtN1XDscOExaHDteKAnTrFvcaSax7igJPDgMO9wqbDtEjigLAkWBIcGOKAnsKv xZLFuCfCozgKMcO+LCbDjsKww4bDk8OFWjbCoyLDvwrCosuGZ8KxeTIGw4kmeExkw6fDuEnLhsKn GTvCnQY5w4jDqSsrWsKywrXDlDR7wqtLw509dQt3xZLigJTCtSrCp8ONw4cKw4QMw6QMZMWSHHI6 w5AGwq1ywrrDt+KAun/Doi0nR+KAmUVdNnt7wqvCq8OIduKAmW4WMxLCrGTDpArigJ7DjcK5woEH cE3Cp8OlZgZvCl48w54awrfFoUnDpMK6YMOywqFiwrIXTcKyMsO5Z8OMVXYpwo3igKbLnAZiwqTi gJjigJlrw4rCtcK9VsOnU8W+w7LDtsOnw4XCui7CjwrDreKAmUXCqFpKw4s0w4sWfntZI8OI4oCY GRZJcBAWZhJuaMOyxaDigqwdXsK1w6LDi8OPEXjFvsOvw4F+HsOzw5HDo8KPF1rCtcKoJWDigJwM w4YCw6ARCzBMecK/OVbDiAhIw4jDqsK8O8Oh4oC5bQLDl3Myw5zDqnLCs0tzeApYxZLCsj7DncOs EX5Uw4/igJPihKILw5dgJ3HDiTzCj+KAoXVbfRdDGmfCgTwbwqvDqlbDkMKkcsKlw53DiFs4bwMK fMOfNlwzwrfDkTHDgAMKFsKuwq3Dt8OFGXXCq+KAuU/DrMKNAsOew5PDjVbFoMO5wqXigJlIw5Yu w6vCtDLCu8K/I+KAmcKoMsKNw5nCgQodN+KAuVbDncO8McKpQ3N/FsW+wrLDm8KyJcOkw7J5ccOA w6cBHMK+RghywqRzxZPFvSvFk8K1w7jCo8Knw6rDmjrDnWgaPsKxwqvDnMOIUiXigKALR1TFvWZc w6zigJlmGxNpKhnCskDDnAjDiMOOKsO4Y8Ohw5bigJzDocK9cUzDtjJqw5figJRJw7bDg8KrXy/L nMOpOjDDn8OUYjJLwqvCocOlw44kw4nDuUV6UApnGMO8BSB5w47Co2/Do8OPEwvigJ3CjcO/CsOh FxbDsCtbBeKAkyvigJh1cCXDnAs4w4kRbUUYw5rCpOKEog5DAcK0w4/CoWnDnxBswq3CrTTDqSXD sMK14oCiwo3CtcK4woFaGMKubhxtG1cBwp04w4BR4oCZw4TDscW+w7XDqDRQB8W+w51efEBtbsOj S8OTLnwxcSXCtcK8E8K7w5zDmcOcQDbDiMOSwq4Gw5lfwqHigKHDtcOtxaDCt2Mnw4TCqMKuC8Oq NsK+FMK5y4Ypw5sdwrXDhcOMLcK7w5dzI8KPw4Mfwo10wrFpw7DCpsKxccKpBuKAnMOOwrjigJoo HXjDmhY24oCY4oCdxb0zxZPDisOZw6fCsMOgc8KdKgrDs8Orwrk8Z8Kma+KAlBrDjcK34oCmdMOt SkvigLpobT7Dj2vCrG1ow4RtK8Ouw50kKAg+aBgdNsO3w48Rw5h4w5/DhhdawqTCtnPDvD3FoSNu V8OtAi1ew53DpEVh4oCiZVbDmhgcEcKQceKAomHFk8KpA8ORaybDq0t5wrVbK8OobhoXxpJ6TsKq wrkXETLFuMKQw7PDgQ/CtcaSdRhgMB3CqAPigKLCssOXwrVNAsOLUMK7w5R8IcKvw4s9w43DrMKz w4jDlsKrbzllLcKyChI54oCww4rDgsKxKcOAw6rCpMWTw7LDhX/DoWnDvwrDlOKAsMOjf8O8FH/D tnXDn8ORQBzCvF42w5PFvgXigJNLHXYcwq5ZX0XCuyU94oCwERHDuRNYw4PDo2fDg8Ouw7rDvgfC r8OYw64/w7jDnXoKY2p6Z8O24oCmw4bigJTCvlHDpcOaXeKAueKEoiNlw5zCs21HCgjDj8Owwrsj 4oCac+KAmuKCrMO1w4HCoA5bw4FeNcOwwrReD8OSwr7DkcOiPSYrwrlgE8OdwqzDl8KxwqPDvcKi Ql5SVcuGCuKEohnDjjAKw48cYsK6BMOxwr/igKZk4oCYUTxNwqLCuzHDgAvCqERJJ8KgA3daw6hA w4d6w6figLrDgMOeFeKAmUbigJlPDMOow47DrEsWawjigLAkw7XDj8OLw40KL8WSw4kaLcKuCMO/ CsKQwq7CncOXw77CvyHCruKAoMK8xbhQw7DDn+KAocO0wo/FoHY6xZMabuKAmMKnw6nDunXigqzi gJRQ4oCZw6Fi4oCgw54Sw7Iwwrd4w4cYy5zCujgsw5xtAx82K3rDh8OiFHd6w47ihKIMxaFFw6XC psKNwqoGSwpWw6jigJ5L4oCwwrPigKJQwp1VXX5kL8K0wrdAwr3DqAPCusKvMcO44oC5w6HigLrD iyt7w58Zw7hzUjp2wrVtbBpcQxlLy4bDog7DjcK44oCiJztOeSVP4oCT4oSiGVVlw7TDqsOmdeKA usOtQsOyaXTCjQJowqPCv1XDvwpIwr3igJM/MjsgRkfDi8KQHlIOQnQK4oCgbALCocOAOQ8Ow6rD rC104oC6wo8LaXfCkMODcwPDnl3DqFIFEUDFvcOMROKAmMK7f8KrLsOrw7vCtB8jxpLCncKpw7M6 w6rDh8OiPR5tfGpeCsK94oChR+KAmcOLw4zigJrDl0/DlSXFvRlUxbjigKLDpzk4bMOtKMKtGWXD ml/DpiXihKJTwqbDkHQbLw5pa2FiJArCueKAk2nCpm3DssOcSsOcwrTigJkxw6XCncKPU8O4DCAg w5hlw4kHwqEdCiBzxpLDhjo0wqPDjMK24oCTw6rDrj7igLkl4oCi4oCdw7cpIMO1RsKNGDgH4oCa VyFPCsaSwoFRw6g+LDrDlsKrLcWTw5p0wrYKwqzigKDDm8ONwpA7w4hh4oCdw4U6wrBcwqrigJ19 wr0ZxpIHUg9QOmAwScO2FcOJaFpd4oCU4oCwfh7DqDHDq8K2w4nCqQl0w7t5xZNefsO04oSiGiHi gJTDi2TDrsOlwr5uwqMnBuKCrBNfw5UswrXigLBtdEhk4oSiwqXCuMK7CxXDnCjCskMKw4wFwqZU 4oCcw6YEw7MDBkXDueKAoDDDhTcpO1oOwqEmwqvCollfSQnigJpLy4YSWQpj4oCcE+KAmMOzIcOp w4rFk8aSw4DDpHQVSsOvw4MWw6/DoVvCvQrDikfCtsWgVMKQw4c0xZLDkzxTMxfDs3c7Fiwcw68E xZPigJoBBGBXMMWhJsW4bwrCvsW+w74Ww5UuwqdFEcOHYTXDtMO3OnBQwrtVw4tKw4Y/LBAGCnnG kgHigJ5nIMKQDsOnUMOVLXTLnBJ7wrbigJwyPsOESGJ5XkbDgThUQFnFvQE4CsOgAnoCa8WSw7Eo w7h3w6JI4oCYdcOLw50mO8K5CmTFoFvigJTFvRvLhsKBEkZ44oCcBBVjJ8OKw4PDpXHFkwYVf8OC 4oCTNlbDl8K6xaAPCsOpCk1hcnRpbiBCaWxncmF2IHdyb3RlOgo+ICJDZW4iIDx0ZXN0X25vc3Bh bUBzcGFtbWVyLm5ldD4gd3JvdGUgaW4gbWVzc2FnZQo+IG5ld3M6ZGdwNWRoJDJpdXAkMUBvdGlz Lm5ldHNwYWNlLm5ldC5hdS4uLgo+ID4gTG9va3MgbGlrZSB5b3UncmUgZG9pbmcgb25seSAxIFZM QU4uCj4gPiBNYXliZSB0aGUgY2lzY28gd2FudHMgdG8gbmVnb3RpYXRlIHRydW5raW5nLgo+ID4K PiA+IHRyeToKPiA+IHN3aXRjaHBvcnQgbW9kZSBhY2Nlc3MKPiA+IG9uIHBvcnRzIHRoYXQgYXJl IGNvbm5lY3RlZCB0byBIUC4KPiAKPiBKdXN0IG15IHdvcmRzICsgTm8gbmVnb3RpYXRlCj4gaHRo Cj4gTWFydGluCg==
