Anyone can tell me if the ASA5510 can make GRE tunnels?
thank you!
Xavi
Hi Xavi, To my knowledge ASA devices currently can't terminate a GRE tunnel. If it is essential that the device does terminate the tunnel and you need firewall (or other) functionality then an 1800 or 2800 series IOS Router may fulfil your requirements. If you need to run a…
Read the full replyAnyone can tell me if the ASA5510 can make GRE tunnels?
thank you!
Xavi
Hi Xavi,
If you need to run a routing protocol over a tunnel then the following link may help:
Hope this helps.
Joe ========================== Igneous Networks Technical Director
