Cisco ACS 3.1 problem
Dec 24, 2006 0 Replies
Hello, I have the following problem with Cisco SEcure ACS 3.1
I am unable to start the management interface as https service.
I first install a X509 certificate and the CA certificate. Everything goes fine. But at this point when I Start the https service I am no more able to enter the management interface, because it gets simply blocked. I have to come back to the default http configuration chenging the registry value
HKEY_LOCAL_MACHINE\\SOFTWARE\\Cisco\\CiscoAAAv3.2\\CSAdmin\\Config\\HT TPSSupport
to the default value.
On ACS 4.0 I do not have this problem. Is it a bug of acs 3.1 ? How may I solve this ?
thank you
Rick
