Cisco 877 Router with Speakeasy DSL Trouble
Apr 06, 2007 1 Replies
Hey everyone. We just installed a Cisco 877 with the ATM interface for use on a Speakeasy DSL connection. I went through the SDM and the ATM interface links up just fine and Speakeasy has confirmed being able to ATM ping the interface but that's it. I can't ping out from the router let alone any of the Ethernet ports on the VLAN.
I then wiped the config clean and used the following. The ATM interface links up fine but still nothing gets out. Please let me know if anything looks wrong. Note on the IP route I also tried using the Speakeasy gateway instead of the ATM interface.
I can't imagine this to be as complex as it's starting to seem. Thanks in advance.
! version 12.4 no service pad service timestamps debug datetime msec localtime service timestamps log datetime msec localtime service password-encryption ! hostname bfd ! boot-start-marker boot-end-marker ! enable password 7 (secret) ! no aaa new-model ! resource policy ! clock summer-time ACST recurring last Sun Oct 2:00 last Sun Mar 2:00 ip subnet-zero no ip source-route ip cef no ip dhcp use vrf connected ip dhcp excluded-address 192.168.1.254 ! ip dhcp pool CLIENTS network 192.168.1.0 255.255.255.0 default-router 192.168.1.254 dns-server 64.81.159.2 216.231.41.2 ! ! ip domain name speakeasy.net ip name-server 64.81.159.2 ip name-server 216.231.41.2 ! ! ! username bluecc password 7 (secret) ! ! ! bridge irb ! ! interface ATM0 description no ip address no ip mroute-cache no atm ilmi-keepalive pvc 0/35 encapsulation aal5snap protocol ip inarp ! dsl operating-mode itu-dmt bridge-group 1 hold-queue 224 in ! interface FastEthernet0 ! interface FastEthernet1 ! interface FastEthernet2 ! interface FastEthernet3 ! interface Vlan1 ip address 192.168.1.254 255.255.255.0 ip nat inside ip virtual-reassembly ! interface BVI1 description --- Bridging Interface --- no ip address ip nat outside ip virtual-reassembly ! ip classless ip route 0.0.0.0 0.0.0.0 ATM0 ! no ip http server no ip http secure-server ip nat inside source route-map internet interface BVI1 overload ! access-list 1 permit 64.81.159.0 0.0.0.255 access-list 1 permit 216.231.41.0 0.0.0.255 access-list 1 permit 66.92.133.0 0.0.0.255 access-list 101 permit ip 192.168.1.0 0.0.0.255 any route-map internet permit 10 match ip address 101 ! access-list 101 permit ip 192.168.1.0 0.0.0.255 any route-map internet permit 10 match ip address 101 ! ! control-plane ! bridge 1 protocol ieee bridge 1 route ip ! line con 0 no modem enable transport output all line aux 0 transport output all line vty 0 4 login local transport input all transport output all ! scheduler max-task-time 5000 end
I have never seen a dsl router working without a dialer interface and ppp.
