Catalyst Express 500, dot1x, VLAN membership
Sep 14, 2006 0 Replies
Hello,
I've a CE500 switch with dot1x authentication on Microsoft IAS server.
I'm trying to use dynamic VLAN assignement based on user authentication.
I setup a policy on IAS to assign the following attributes to some groups:
Service-Type: Framed Tunnel-Medium-Type: 802 Tunnel-Pvt-Group-ID: MY-TEST-VLAN Tunnel-Type: Virtual LANs
I can see on the IAS logs that the policy is applied, the switch brings up the connection but the port is on native VLAN (that is it is not assigned to MY-TEST-VLAN).
I've created manually the VLAN on the CE500 usign CNA and the security level is HIGH for all the FEs. The FEs are assigned with the role DESKTOP on native VLAN 1.
Could someone tell me what I'm wrong and is this could be done on a CE500?
Regards ermmau
