Can't NAT from outside with PIX 515
May 02, 2006 4 Replies
Jump to replies (4)
Hi.
I have a this testing environment:
outside security 0 - public range /26 inside security 100 - 192.168.10/24 dmz security 75 - 192.168.0/24
there is an "permit ip any any" applied in all interfaces.
then I have
static (inside, dmz) 192.168.0.101 192.168.10.101 netmask
255.255.255.255 static (dmz, outside) 200.200.200.200 192.168.0.50 netmask
255.255.255.255
my computer is 192.168.10.101 in inside, a web server is configured at
192.168.0.50 in dmz.
From inside, I can connect to my web server as it should.
>From outside I can ping my web server, but cannot connect to anything,
http, ssh, telnet. It always gives me a connection timeout.
This same web server works perfectly with public when I use a cisco
1605 with nat like this:
ip nat inside source static tcp 192.168.0.50 80 200.200.200.200 80
Any tips?
And I forget to include this: It uses software version 6.3(4).
Did you happen to use the -same- access-list name for each of the access-group statements? If so, that could explain the situation.
You only need the static (inside,dmz) if you need the dmz to be able to initiate connections to the inside, or if for some reason you need your inside computer 192.168.10.101 to be recorded distinctly as 192.168.0.101 on the dmz (e.g., for authentication reasons.)
Otherwise, if you do not need to be able to initiate to inside, you could
nat (inside) 2 192.168.10.101 255.255.255.255 global (dmz) 2 192.168.0.101
Also, -typically- if you want an inside host to appear as a unique IP address to the dmz (e.g., logging purposes), you would static the IP to itself, or use nat 0 access-list to do much the same thing.
static (inside,dmz) 192.168.10.101 192.168.10.101 netmask 255.255.255.255
That behaviour would not surprise me if you have used the same access-list for all three access-group .
As I said, this is a test setup to solve the problem. It's not our real network layout.
The static (inside, dmz) is proposital, and it's not a problem at all. The problem is that I cannot open a page in the web server from outside with nat and no restriction.
About the ACLs, they are not the same. There are 3 distinct acls with "permit ip any any", one for each interface.
open an connection from an lower security interface to a higher security interface using static and ACL.
But the same thing doesn't happen with connections coming from outside to dmz, although it's exactly the same setup.
I suspect this PIX have a hardware problem... did anyone have the same problem?
[PIX 6.3(4)]
Is the 200.200.200.200 exactly the IP address of the outside interface? If it is, then replace it with the word "interface" and use PAT:
static (dmz,outside) tcp interface www 192.168.0.50 www netmask 255.255.255.255 static (dmz,outside) tcp interface telnet 192.168.0.50 telnet netmask
255.255.255.255 static (dmz,outside) tcp interface 22 192.168.0.50 22 netmask 255.255.255.255
