Cisco ASA 5520 VPN Client Question
Sep 11, 2007 0 Replies
Hello all,
I have a ASA 5200 box that I've configured for client VPN connections. I have it set up to hand out DHCP addresses for the network that the box is connected to on the inside. When I connect to the box with Cisco client software, everything works fine and the box assigns me an IP address from the DHCP pool. Below is what my routes look like after connecting to the ASA 5520:
Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.101.253 0.0.0.0 255.255.255.255 UH
0 0 0 eth0
192.168.111.0 0.0.0.0 255.255.255.0 U
0 0 0 cipsec0
0.0.0.0 192.168.111.1 0.0.0.0 UG 0 0 0 cipsec0
However, once I'm connected via the tunnel, I cannot get to any boxes on the inside network. I have a test web server set up on the inside network that is configured with an address on the same subnet of the address assigned to the VPN client. I try and go to this box and I can't get there, my browser times out. It seems odd to me that the default gateway of the client is itself, as I would have figured it would be the IP address of the ASA 5520 box. I considered adding a static route in the 5520's configuration, but I'm not going to a different network a static route wouldn't apply in this case. I looked through the 5520's configuration options, but did not see anything for configuring the gateway address to hand out to clients.
Any suggestions on this problem? Thanks! -- BTR
