C870 PPPoE
Oct 29, 2007 7 Replies
Jump to replies (7)
Hi there,
a quick question about PPPoE. How do I configure a reconnect on a C871 if the line is terminated by the ISP? The router needs to be always available to the WAN Side.
Thank you.
Andy
"Andreas Heinzelmann" wrote in news:fg49ur$84p$ snipped-for-privacy@news.albasani.net:
Search for the option "dial-on-demand" in your config and delete it....
Gruß, Carsten
Also check out the dialer persistent feature to see if it is available on your router:
Dialer Persistent Plus Failed Connection Delays
">> Hi there,
And thats about it? If the ISP cuts the line the Box will automaticly reastablish the connection? Is this the IOS-default? Thanx for your help!
"Andreas Heinzelmann" wrote in news:fg4g8r$kr8$1 @news.albasani.net:
It works for my 871 and a german Telekom-ADSL line...
Regards, Carsten
you could try the command "clear interface dialer x" where x is you dialer interface
to see if the PPOE session is re-established
Carsten Schneider wrote in news:Xns99D884EEF141Dschneidcgmxnet@139.23.33.23:
PS: In this situation my router is offline for about 3 secondes...
Regards, Carsten
Well, I will try as soon as I am at the box. But I have another question. Do I have to do Anything on the Firewall to access the Router from the WAN Interface. I would like to be able to ssh and SDM (via https) the Box from remote.
Thanks...Andy
