Bridging NetBEUI over a GRE link
Feb 11, 2007 1 Replies
Hi.
I'm trying to get a GRE-over-IPSec-over-DSL link to bridge NetBEUI, but I can't seem to find a way to do so. I had a suggestion earlier regarding bridge commands, but I can't seem to find them on the boxen (it involved the SSAP and DSAP).
I'm using Cisco 837s and an 831.
I today came across a suggestion to use L2TPv3 instead, if that's the way to go I'll have to reconfigure these routers to do so, but L2TP isn't listed on the product page as a supported protocol.
I would be somewhat (British understatement) surprised if GRE tunnels did not do bridging. Have you tried that?
OOPS! I have had bit of a try and it doesn't appear to work.
Maybe you need to look at DLSW? IIRC DLSW can do transparent bridging (not only token ring source route bridging).
