BGP Route Question
Oct 27, 2005 3 Replies
Jump to replies (3)
If I currently have BGP setup as so:
PROVIDER A ---> ROUTER A ROUTER B
On 27.10.2005 15:06 Matt wrote
Unless you enable bgp multipath you only will have one route per destination.
Yes, but not with peers sending full table each,
Arnold
Even with multipath I think you'll only get one route. IIRC, multipath will only install multiple routes if they all came from the same remote AS. Since these are three different providers, they'll be different ASNs.
I guess, it might be difficult with full 3 BGP sessions.
-- Raqueeb Hassan Bangladesh
