Basic Firewall Question
Sep 16, 2006 2 Replies
I'm not completely familiar with how ACLs work in conjunction with the firewall, so I have a basic questions whic should answer what I need to know.
Here's the configuration:
Remote Host=====1811 Router=======Internal Server
FE0 is hooked up to ISP Internal network is VLAN1 Internal server is on VLAN1
Internal server has public IP of 1.2.3.4 and internal ip of 10.9.8.7 using static NAT.
How can I block inbound access to a single port (say 1433, for example) originating from a remote host (ie any internet machine) to that internal server and then allow all other traffic?
I'm trying to block a specific set of ports on FE0 but want to allow everything else to flow freely.
access-list 101 deny tcp any host 1.2.3.4 eq 1433 access-list 101 permit any
Or udp or ip replacing tcp above. For a range say "range 1433 1455"
int fe0 ip access-group 101 in ...
alan
Thanks. That's exactly what I needed to know. I basically just needed to know the general syntax.
