Bandwidth limiting per host
Jan 23, 2006 5 Replies
Jump to replies (5)
Hi, I have applied the following rules of limit a particular host to
128Kbps. But I don't think its working. Any wrong with the following ? Please guide.
The router is Cisco 3620 with Version 12.2(12).
interface Ethernet0/0 ip access-group 101 in rate-limit input access-group 101 128000 16000 16000 conform-action transmit ex ceed-action drop rate-limit output access-group 101 128000 16000 16000 conform-action transmit e xceed-action drop full-duplex
access-list 101 permit ip host xx.xx.xx.xx any access-list 101 deny ip any any
Regards baruah
Hey there,
That's kind of right, but you could tweak it a bit better. With rate-limiting you are giving 128k bandwidth with 16k burst each time period, effectively giving 256k. Which is probably why you don't think it's working.
It would make more sense to build it this way, using the mcq:-
access-list 10 permit host w.x.y.z
class-map match-any SpecificHost match access-group 10
policy-map SqueezeHost class SpecificHost police 128
interface e0/0 service-policy input SqueezeHost service-policy output SqueezeHost
This way your chap will only get 128k tops. I would use a standard access-list if you are specifying a single host. If you want to use an extended, then make sure that you catch both to and from traffic.
Enjoy
LH CCIE#15331
snipped-for-privacy@yahoo.com wrote:
One minor typo:
... should read "mqc", not "mcq". MQC stands for "Modular QoS CLI".
Also, I suspect everyone will be happier if you _shape_ the victim host to
128Kbit/sec, as opposed to _policing_ to 128Kbit/sec.
Bruce Lueckenhoff
-- snipped-for-privacy@ScalableDesign.com
Good calls Bruce
snipped-for-privacy@gmail.com wrote:
Hi, Thanks for the reply.
But its still not working that way also. When I measure the bandwidth from x.x.x.x(client pc) its shows very high download spead. The network is like this:
x.x.x.x------------------->Cisco router( where this is done)----->Backbone router---->Serial link.
Cisco Router got single ethernet card and its gw has been set as the IP address of "Backbone Router".
Please suggest. I want to limit each and every user passing that Cisco router.
regards baruah
Leigh wrote:
Hey there,
What kind of download speeds are you getting? 128k bandwidth is not too slow a link for a single user.
Could you post the bits of config that you have put on ?
LH CCIE#15331
