ASA 5510 - port forwarding to external
Jul 24, 2008 3 Replies
Jump to replies (3)
ASA 5510 - port forwarding to external open original image
We have a VPN into our colocation facility and need to enable the following scenarios for different vendors/clients.
  1. Forward all messages on a port to a vendor/client address. Two options here a) Down another VPN on the ASA - preferred b) Directly to an external address
  1. Same as above, but also configure an internal route on the same port
We have been told by one consltant that this will probably require another ASA, but I am not sure we are getting the correct answer. Does anyone know if this is possible?
Are the different vendors on different subnets? If so I do not see any reason why you would not be able to create ACL's sufficient to restrict traffic to the specified ports/IP address.
That is what I thought, as well. I am just not very Cisco savvy, so I figured I would ping.
No problem, if you need further help with the design or config, post some additional details and the people of the group should be able to assist you!
