ADSL ET RNIS SUR CISCO 1801
Oct 10, 2005 3 Replies
Jump to replies (3)
Bonjour,
Nous souhaitons utiliser le CISCO 1801 avec module ADSL et ISDN en meme temps : ISDN backup de ADSL
N=E9anmoins aucune version IOS test=E9e ne permet leur mise en place en meme temps.
12.3 (14)YT1 ADSL fonctionne et ISDN non 12.3(8)YT1 ISDN fonctionne et ADSL non
ci-dessous un debug avec version 12.3 (14)YT1
#debug isdn events
#isdn test call interface bri 0 092921500
*Oct 10 12:04:26.042: ISDN BR0 EVENT: UserIdle: callid 0x8024 received ISDN_CALL (0x0)
*Oct 10 12:04:26.042: ISDN BR0 EVENTd: UserIdle: Call to 092921500 at
64 Kb/s
*Oct 10 12:04:26.042: ISDN BR0 EVENTd: isdn_get_guid: Got Guid D640B9538025
*Oct 10 12:04:26.042: ISDN BR0 EVENT: process_bri_call: call id 0x8024, called_n
umber 092921500, Guid D640B9538025 speed 64, call type DATA, bchan -1 clng_num n
one
*Oct 10 12:04:26.042: ISDN BR0 EVENTd: process_bri_call: No name in GTD
*Oct 10 12:04:26.042: ISDN BR0 SERROR: isdn_get_display_text_from_gtd: false ret
*Oct 10 12:04:26.042: ISDN BR0 SERROR: isdn_get_mlpp_from_gtd: MLPP from GTD failed
*Oct 10 12:04:26.042: ISDN BR0 EVENTd: calltrkr_setup_received: isdn_info=3D220691
2444l, call_id=3D0x8024 ORIGINATE
*Oct 10 12:04:26.042: ISDN BR0 EVENTd: calltrkr_setup_received: calltracker disa
bled
*Oct 10 12:04:34.042: ISDN EVENTd: cc_clear_free_list freed 0x83C5BDA4
*Oct 10 12:04:34.042: ISDN BR0 EVENT: process_rxstate: ces/callid
1/0x8024 callt
ype 1 HOST_DISCONNECT_ACK
*Oct 10 12:04:34.042: ISDN BR0 EVENTd: calltrkr_call_cleared: isdn_info=3D0x838ACF
BC, call_id=3D0x8024
*Oct 10 12:04:34.042: ISDN BR0 EVENTd: calltrkr_call_cleared: hndl=3D0l, cause=3D0,
Unknown cause value
*Oct 10 12:04:34.042: ISDN BR0 **ERROR**: host_disconnect_ack: Unfound B-channel
on Disconnect_Ack call id 0x8024
Par contre dans la version 12.3(8)YT1, l'interface ISDN fonnctionne parfaitement. Le m=EAme debug donne le r=E9sultat suivant :
*Oct 10 12:01:50.087: ISDN BR0 EVENT: UserIdle: callid 0x8005 received ISDN_CALL (0x0)
*Oct 10 12:01:50.087: ISDN BR0 EVENT: process_bri_call: call id 0x8005, called_n
umber 092921500, Guid BR0 speed 64, call type DATA, bchan -1 clng_num none
*Oct 10 12:01:50.103: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 65 change
d to up
*Oct 10 12:01:50.307: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x8005 callt
ype 1 HOST_PROCEEDING
*Oct 10 12:01:50.911: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x8005 callt
ype 1 HOST_CONNECT
*Oct 10 12:01:50.911: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
*Oct 10 12:01:51.911: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0:1, ch
anged state to up
*Oct 10 12:01:56.911: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 0929
21500 unknown
*Oct 10 12:02:00.863: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x8005 callt
*Oct 10 12:02:00.863: %ISDN-6-DISCONNECT: Interface BRI0:1 disconnected from 09
2921500 , call lasted 9 seconds
*Oct 10 12:02:00.863: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down
*Oct 10 12:02:00.939: ISDN BR0 EVENT: process_rxstate: ces/callid
1/0x8005 callt
*Oct 10 12:02:01.863: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0:1, ch
anged state to down
Any help
Bonjour,
#debug isdn events
64 Kb/s
one
bled
1/0x8024 callt
Unknown cause value
d to up
ype 1 HOST_CONNECT
anged state to up
21500 unknown
1/0x8005 callt
anged state to down
Any help
Bonjour,
#debug isdn events
64 Kb/s
one
bled
1/0x8024 callt
Unknown cause value
65 change
d to up
1/0x8005 callt
1/0x8005 callt
ype 1 HOST_CONNECT
anged state to up
21500 unknown
1/0x8005 callt
1/0x8005 callt
anged state to down
Any help
J'ai un idee.
Peut-etre les "defaults" pour les deux versions sont differents.
Il y a aussi le 12.3(8)YI3 . C'est gh[I]jk trois, ne pas treize. Peut-etre, le quatrieme fois, il va bien. Zero (ou rien), un, deux, trois.
debug isdn ... debug isdn q931 debug isdn q921
Je regret que je n'ai pas des accents et que je n'ecrie pas francais si bien.
Bonne chance.
++++++++++++++++++ Possibly the defaults in the two versions are different.
You could try 12.3(8)YI3, maybe the 4th build was better.
Also I think that you can turn on more ISDN debugging.
